Support the club!
Mondeo 53 Estate Rear Light Cluster
4 replies to this topic
#1 ish
ish
    Newbie
  • Pip
  • 3 posts
  • Ford Model: Mondeo Estate
Posted 12 January 2013 - 06:30 PM
Need help in getting to the off-side rear light cluster to replace an indicator bulb.
Any help appreciated as most of my driving is in the early morning and late evening - thanks...
#2 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 12 January 2013 - 11:46 PM
is it not just unclip the rear carpet surround, then upclip the rear cluster?
#3 ish
ish
    Newbie
  • Pip
  • 3 posts
Posted 14 January 2013 - 06:40 PM
Thanks Martin,
No, the rear light cluster goes up to the top of the rear pillar.
However, I worked it out - there are two access points/removable panels. One is 'carpet type material' about 6 inches up from the floor - that's why I couldn't see it! The other looks like a 'speaker grille' near the top of the pillar. Remove these to get at two 'thumb nuts' and watch out for the sharp edges - not a lot of access space. Undo those and lift/pull out the light cluster from the outside.
Access to the bulbs in now possible.
Re-assembly is the reverse - push the light cluster back into position, re-install the 'thumb nuts' taking care not to drop them, then re-install the 'trim'.
Took about 5 minutes...
Thanks again...
#4 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 14 January 2013 - 07:42 PM
my bad, glad you worked it out ;-)
#5 ish
ish
    Newbie
  • Pip
  • 3 posts
Posted 20 January 2013 - 10:53 AM
Hi Martin, Your bad??? Not at all.
At least now there's a procedure for others to follow.
Now, I've just had to do a left front headlight bulb!! Had to dismantle the front of the car... almost. And it's different to the Mondeo 02 plate I had previously.
Ford don't make these little jobs easy for us, do they?
