Ford C Max 1.6 Tdi 54 Plate Cutting Out !!!!!!
19 replies to this topic
#1 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Ford Model: Ford c max 1.6 tdi
  • Year: 2004
Posted 15 January 2013 - 09:44 AM
It all started with what felt like a slight flat spot a few weeks ago. Today, car started fine, all going well for about 3 miles then suddenly at about 3000 revs a puff of black smoke and complete power loss ( all electrics stayed on ) had to re start engine while rolling down dual carriage way lol. Started first time, all was fine till between 3/4000 revs and same again. No engine fault lights. This car has had a new Egr valve less than 9 months ago, but when that happened, there was engine fault light, and it was in limp mode, this is not the same. Please help, any ideas appreciated. Thanks, Tom.
#2 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 15 January 2013 - 10:04 AM
Hello and welcome,
It sounds like it could be fuel starvation, I would start with the fuel filter and go from there
#3 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 15 January 2013 - 10:18 AM
I had thought that too (Or maybe a failing fuel pump) but isn't the throttle of a diesel control by fuel flow (As opposed to a petrol car that is controlled by airflow), and therefore if the flow was restricted (Due to a dirty fuel filter or failing fuel pump) then wouldn't that just prevent the car from accelerating any further, rather than actually cutting out?
I guess its not that simple with a turbo car as the fuel flow and airflow need to be in balance, so maybe with the fuel restricted the ECU detects that the mixture is way too lean and therefore cuts the power.... but if this were the case then I'd expect to see a fault code.
#4 jeebowhite
jeebowhite
  • 4,307 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 15 January 2013 - 10:38 AM
I would say your looking for fuel starvation, but perhaps not due to lack of fuel. It's often seen that you get air sucked into the fuel lines through an old filter then it's more suffocated by air than starved of fuel.
#5 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 15 January 2013 - 10:45 AM
Would u say to start with the fuel fitter and are they hard to change never changed a td one
#6 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 15 January 2013 - 10:56 AM
And how come at idle I can rev to max and not a thing just like normal
#7 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 15 January 2013 - 11:21 AM
At idle it will take less fuel to get the engine revving hard than it does when under load
#8 jeebowhite
jeebowhite
  • 4,307 posts
  • Name: James
  • Year: 2005
Posted 15 January 2013 - 03:21 PM
And the more load, the higher the pressure in the pipes, and the higher vacuum rate, which means that there is more risk of sucking air into the system...
#9 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 15 January 2013 - 03:25 PM
But there was loads of black smoke when it 1st than it now none lol just drive no problem them does it i just dont wont to spend 60 pound and its not it lol
#10 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 15 January 2013 - 03:37 PM
With no warning lights or otherwise your only other thing to consider is getting it hooked up to a live data scanner and looking for any odd readings.
#11 jeebowhite
jeebowhite
  • 4,307 posts
  • Name: James
  • Year: 2005
Posted 15 January 2013 - 03:55 PM
The black soot sounds like the exhaust was clogged, this would reduce the cars natural breathing and would starve you of power / suffocate the car.
Call your local dealer, give them the number plate, and get them to confirm if you have a DPF, dependant on the mileage, you may find that you need to add EOLYS fluid, or replace the DPF (again, only if you are equipped with one)
#12 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 15 January 2013 - 10:31 PM
I had my egr valve change 9m ago so sure it's not that as for fuel filter how come I can turn key of then on again and it starts ok I unplugged maf sensor to and went round went for 10 mins and did it again so can't be maf sensor lol I do still love fords I do lol
#13 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 16 January 2013 - 06:30 AM
If it did it again with the maf sensor unplugged then that could be your answer.
#14 Tommy3010
Tommy3010
    Member
  • PipPip
  • 11 posts
  • Year: 2004
Posted 16 January 2013 - 08:17 AM
I was taking it as it wasn't that lol how you take it
#15 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 16 January 2013 - 09:25 AM
If unplugging it has no affect on its running then it would indicate that it's faulty, with the maf sensor unplugged the car will generally run pretty poor.
If you have access to a live data reader you could confirm this
