colin2
Technical Knowledge
Help in spot of bother had rough running on engine low compression.Removed cylinder head found burnt valves No 3 cyl replaced put all together start up running still poor.one thing not done checked basic valve clearance could anyone tell me what they should be got fiesta lx 1.25 zetec engine
Whats the engine code?
Be a mk4/5 then?
All engine codes on the 4 or 5 begin with DH then either have A,B,C or D for the mk4 or E,F or G for the mk5
Be a mk4/5 then?
Found on same label E1
Lets go for that
Assuming the engine code is DHE...
Inlet - 0,17-0,23 cold
Exhaust - 0,23-0,33 cold
Hope this helps
Hope this helps
Thank you for the infomation
