Is It True?
5 replies to this topic
#1 Preload
Preload
  • 30 posts
  • Ford Model: 1.6 Dura Titanium
Posted 16 January 2013 - 06:53 PM
I have been told that my TDCI 59 1.6 Focus doesn't use Eloy at all is this right as I dont want the DPF blocking up?
#2 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 16 January 2013 - 07:03 PM
myself i think it does but am unsure, but i was told if you look under the car, on the right hand side where the subframe is, you should have a bottle where the fluid is put into.....
#3 Preload
Preload
  • 30 posts
Posted 17 January 2013 - 10:29 AM
Thanks I'll have a look see..
#4 Lenny
    Resident Sherpa
  • 5,332 posts
Posted 17 January 2013 - 10:44 AM
I too would like to know if my DPF sips on pigs wee wee or not. (Pig wee is main ingrediant in eloys fluid)
So is the bottle in the engine bay or near the fuel tank in the rear ?
#5 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 17 January 2013 - 08:19 PM
as far as im aware its by the fuel tank under the rear of the car.....
#6 jeebowhite
jeebowhite
  • 4,311 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 18 January 2013 - 01:41 PM
Best answer, call your local dealer/s and give them your number plate / VIN, if your car has it, they should be able to tell you.
If not... try another dealer!
The EOLYS fluid is added after a certain amount of fuel is input into the tank. its injected straight into the fuel tank, and so, needs to be close to the fuel tank. If you look up from the underside of the car, up to the area where the fuel door is then you should see it around that area.
