Steelman Posted March 7, 2009 Share Posted March 7, 2009 Hi folks. Be gentle with me as I'm a newbee!! I'm getting a groaning noise from my steering on my T reg Focus. Driving me mental!!! The steering is smooth & not heavy. Only happens lock to lock. Any helpful surgestions would be great. Thanks Pete Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted March 7, 2009 Share Posted March 7, 2009 Is it power steering? Does the noise only happen when on full lock? Quote Link to comment Share on other sites More sharing options...
Steelman Posted March 7, 2009 Author Share Posted March 7, 2009 ]Yes, it is power steering & it happens on either lock. Its more pronounced if you rock the steering wheel from side to side. Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted March 8, 2009 Share Posted March 8, 2009 If it only happens when you hold it on full lock dont worry as this is normal. If it happens when rocking the steering in any other position then the pumps probably knacked. Make sure there's plenty fluid in the system, if not check for leaks. Quote Link to comment Share on other sites More sharing options...
Steelman Posted March 8, 2009 Author Share Posted March 8, 2009 If it only happens when you hold it on full lock dont worry as this is normal. If it happens when rocking the steering in any other position then the pumps probably knacked. Make sure there's plenty fluid in the system, if not check for leaks. Quote Link to comment Share on other sites More sharing options...
Steelman Posted March 8, 2009 Author Share Posted March 8, 2009 It happens when turning from lock to lock & not when holding it on full lock. Also, it only seems to happen when car has been travelling a while ie, when it has warmed up. If it is pumps, what pumps are they as my tool kit consists of one big hammer & a grinder!!! Thanks PETE Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted March 11, 2009 Share Posted March 11, 2009 Sorry for the late reply. Been rather busy at work lately :( Sounds like your pumps on its way out but without hearing the noise myself I cant say for sure. Could be the rack. If your a complete novice with cars I wouldn't recommend doing it yourself. The steering pump sits on the drivers side near the front headlamp. You will need to remove the alternator belt and drain the system first before taking the pump off. Quote Link to comment Share on other sites More sharing options...
Steelman Posted March 21, 2009 Author Share Posted March 21, 2009 Hi Folks. Sorry for the late responce. It turned out to be drag link bushes/antiroll bar thingy ma jigs!!! Anyway, replaced the !Removed! lot & she's fine now. Thanks again to all of you who tried to help. Regards Pete :D Quote Link to comment Share on other sites More sharing options...
