AR-Fiesta Posted January 18, 2013 Share Posted January 18, 2013 Do you's have your plates drilled on or stuck ? Quote Link to comment Share on other sites More sharing options...
iNath Posted January 18, 2013 Share Posted January 18, 2013 Drilled Quote Link to comment Share on other sites More sharing options...
Tony1 Posted January 18, 2013 Share Posted January 18, 2013 Both Quote Link to comment Share on other sites More sharing options...
MartynS Posted January 18, 2013 Share Posted January 18, 2013 Drilled from when the car was new - holes in the front one must be too far apart as the plate bulges in the middle! Quote Link to comment Share on other sites More sharing options...
GJC Posted January 18, 2013 Share Posted January 18, 2013 Reminded me I need a new one, the one the dealer laser printer seems to be falling apart. eBay here I come... Quote Link to comment Share on other sites More sharing options...
TDCiST Posted January 18, 2013 Share Posted January 18, 2013 Drilled, except the original plate was drilled in the wrong place!!! so ive had to do my personal ones to match the holes in the bumper Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 18, 2013 Share Posted January 18, 2013 Mine are drilled, the rear ones when I got the car were wonky and the screws were too tight. Tried removing them to position the plate properly and promptly snapped out the aluminium plugs behind the hatch. Bit of metal putty and better screws tidied up the job. Actually tempted to get a set of locking plate holders off the bay and fit them instead. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted January 18, 2013 Share Posted January 18, 2013 The ones on my Fiesta are drilled. I had to have the back one re-done though as it was bulging badly. I bought some anti-theft number plate screws as they had only used ugly steel heads, which were too big for the caps. Funny thing was, I then realised why they had used such big screws, the holes in the front grille for the plates had burred and were almost useless. I ended up following iNath's guide to remove the front grille, so I could put some make shift plugs on the pack to hold it securely. No doubt they will fall off, if someone ever tries to change the plates Quote Link to comment Share on other sites More sharing options...
