Support the club!
Alarm
5 replies to this topic
#1 rob.forscttuk
rob.forscttuk
    Newbie
  • Pip
  • 4 posts
  • Name: rob
  • Ford Model: 1.8 16v
  • Year: 1999
Posted 18 January 2013 - 05:24 PM
ok so heres my problem, every forum ive seen says that a car with remote central locking should have a alarm, but mine doesnt. if i was to change the module would i have to have all my keys reprogrammed and would fitting the standard module with the alarm work. i can get a module from scrappy easily but would it work if i connected it to mine. i currently have a 1.8 16v zetec it has no steering controls, after market radio (not out of choice) and no temp read, can i add any of these easily.
#2 TDCiST
TDCiST
  • 1,414 posts
  • Name: Dave
Posted 18 January 2013 - 08:15 PM
i'd think you'd have to get it programmed...
Your best to talk to an autoelectrician or any vehicle security business...
#3 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 18 January 2013 - 10:11 PM
could you buy a compatable blank key, get it cut and programmed to your car. as i think with some cars that the immobiliser is worked into the central locking system... but yet again im unsure.... what makes you think your has no remote module? do you have already a remote key but it doesnt work?
#4 rob.forscttuk
rob.forscttuk
    Newbie
  • Pip
  • 4 posts
  • Name: rob
  • Year: 1999
Posted 18 January 2013 - 11:00 PM
i have a remote key and its fully functional, from 2 meters away (think battery needs replacing) but the car has no alarm. now i thought the alarm was part of the remote central locking am i wrong in thinking this. if i change the module would i not as TDCist say and have reprogammed?? ive only just in the past months set up the remote locking and ford charged me £17.50 just for the programming, something id prefer to avoid, if its just over an alarm.
#5 martyntdci
martyntdci
  • 429 posts
  • Name: martin
Posted 18 January 2013 - 11:13 PM
deffo replace the battery, maybe a cr32 unsure tho..... as far now as im aware the imobiliser is enabled through they key in the ignition..... when you lock the doors this then should set up the alarm.... do your hazzard lights flash upon either normal lock, or dead lock?
#6 rob.forscttuk
rob.forscttuk
    Newbie
  • Pip
  • 4 posts
  • Name: rob
  • Year: 1999
Posted 18 January 2013 - 11:19 PM
my hazards flash when i dead lock the car, but even under the door/alarm check when the hazard will flash for each individual door for faults in the central locking the alarm doesnt go off, could i just have a central locking module as i dont have abs fitted either, or radio stalk etc. i seem to have a very basic zetec.
im having to go past my nearest ford dealer tomorrow, so i can find out from them if my car has an alarm, as its all on the cars file, and they may be able to advise whats possible. ill let you know what they suggest tomorrow at some point.
