Centre Console Switch Plates
35 replies to this topic
#1 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Ford Model: Focus Zetec
  • Year: 2009
Posted 19 January 2013 - 11:03 AM
i want to install a SPST switch for my audio and was looking for somewhere to mount it in the centre console, i thought of going for the blanking plates next to heated windscreen etc (i dont have esp button nor the airbag button) but looking on another post it shows a picture of them having a socket on the back,
can it be done? is there a better place to mount it?
#2 Preee
Preee
  • 3,059 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3
Posted 19 January 2013 - 01:09 PM
On a Titanium , the wiring and plugs are there for the Air bag and ESP , they just slot into the blanking plates so you can remove the wires from them and use the blanking plate as you wish.
#3 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 23 January 2013 - 07:28 AM
ok thanks, going try and find some spares on ebay so can try it out, and not ruin my current plates B)
#4 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 02 February 2013 - 08:46 PM
hi guys i changed my mind, and im thinking of adding a switch into the 12v socket in the centre console (hate the sight of the poxy black cover) however as it a 12v outlet ill prob pull it out and leave in under the centre console, the switch im looking at is something along the lines of this
http://www.e-switch....es/default.aspx
can anyone post any pics of the centre console (removal and underneath maybe)
Edit: pv6 diameter too small for socket hole,
#5 Preee
Preee
  • 3,059 posts
  • Name: Paul
Posted 03 February 2013 - 10:05 AM
If you look at my sig below and look at my cup holder guide it will show you how to remove them
#6 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 03 February 2013 - 01:54 PM
brilliant thanks preee, so if i remove the gear stick gaiter i can push it up from underneath
#7 Preee
Preee
  • 3,059 posts
  • Name: Paul
Posted 03 February 2013 - 02:53 PM
No you will have to remove as the guide , first the hand brake cover secured by 2 HEX screws then the Cup holder Screw then it will pull up to allow access to the Garage door chubby securing screws , seems a lot to do but its only 5 minutes
#8 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 03 February 2013 - 04:40 PM
my apologies i wrote the first thread wrong, i want to replace the 12v sock outlet (or engine start button) in the centre console (between cup holder and gear stick) and put in another push button switch
and if i remove the gear gaiter i presume i can push up the socket from underneath and unplug
#9 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,392 posts
  • Name: Clive
  • Year: 2007
Posted 03 February 2013 - 04:48 PM
To remove the socket from above you need to push on two black plastic lugs that you will see on the inside wall of the socket and then draw the socket out.
Careful not to short out the socket with a screwdriver.
You may be better off using wooden or plastic tools.
I have seen the proper tool for removing the sockets on eBay from America but the postage is nearly three times the price of the tool.
http://pages.ebay.co...id=261157370987
#10 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 03 February 2013 - 05:10 PM
haha its looking more work than i thought now haha in my fiesta it was a metal ring that just popped into a hole in the dash (i broke a clip and it kept falling out) i thought it would be the same with this 1
#11 Preee
Preee
  • 3,059 posts
  • Name: Paul
Posted 03 February 2013 - 05:14 PM
It really isn't very hard to get to :)
#12 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,392 posts
  • Name: Clive
  • Year: 2007
Posted 03 February 2013 - 05:16 PM
If you had the proper tool you would only have to push it into the socket to dislocate the two small lugs but anything wide enough to push both in at the same time should work.
Couple of minutes work mate.
#13 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 03 February 2013 - 05:20 PM
ohh i see the lugs are inside the "barrel" not underneath?
#14 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,392 posts
  • Name: Clive
  • Year: 2007
Posted 03 February 2013 - 06:51 PM
Here mate, just to help you along i've knocked up a quick PDF on how to do the job.
Attached File  Removing a 12v Socket and Console Trim From A MK2.5 Focus..pdf   655.24K   47 downloads
#15 vince_13
vince_13
    Vince
  • 239 posts
  • Name: Andrew
  • Year: 2009
Posted 03 February 2013 - 08:48 PM
wow what more can i ask for thankyou :D dont suppose you know the diameter of the hole? (minus the silver ring)
