Replacing Side Repeaters
4 replies to this topic
#1 Jayy-mk6
Jayy-mk6
    Member
  • PipPip
  • 22 posts
  • Name: Jamie
  • Ford Model: Ford Fiesta 1.4 Zetec mk6
  • Year: 2004
Posted 20 January 2013 - 10:36 AM
Just bought some clear side indicators, what's the easiest way to remove them and refit? Thanks (mk6 fiesta zetec)
#2 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,237 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 20 January 2013 - 11:12 AM
Its dead easy, get a very fine flat screwdriver and a towel. Insert the screw driver into the side nearest to the door using the towel so that you dont scratch your paintwork and just pop the indicator out. Its just a small push clip that holds it in, then you need to twist the indicator the remove it from the bulbs holder. Then change the bulb if they send a spare and push and lock the new indicator onto the bulb holder and push the side of the indicator furthest away from the door into place first and clip the other side in :)
#3 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,237 posts
  • Name: Daniel
  • Year: 2003
Posted 20 January 2013 - 11:13 AM
#4 Jayy-mk6
Jayy-mk6
    Member
  • PipPip
  • 22 posts
  • Name: Jamie
  • Year: 2004
Posted 09 February 2013 - 11:43 AM
How do I remove and replace the actual bulb? And Is it best to disconnect the battery?...
#5 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,237 posts
  • Name: Daniel
  • Year: 2003
Posted 09 February 2013 - 12:02 PM
http://www.fordowner...eaters-st-look/
Theres a guide ive made on how to do it. No you dont need to disconnect the battery youbliterally just pull the old bulb out and push the new bulbs in just make sure you use a cloth when handling the new bulb. Because its halogen if you to the bulb with your actual fingers itll make it blow alot quicker
