kevctr Posted January 20, 2013 Share Posted January 20, 2013 hi all im new to the forum and in need off some help iv searched the net and im getting confused with all the answers as they seem to say opasit things i have just brought a 03 mondeo 2.0 130 when u drive the car u get the glow light flashing then car cuts out totaly if u turn it off and on again it will restart and keep going till the next time and so on iv had it checked and results were fault codes are p0251 injector pump meter control ? p1000 test incomplete ? u1039 vehicle speed signal missing or incomplete ? p1211 injector control pressure sensor above/below desired ? i had a diesel leak from the piep that goes up the back off the manifold from injector pump up to the injector rail so iv orderd a new pipe and will be fitting tomorow im in need off some help trying to understand the cause or understanding the fault codes i know these cars have a problem with injectors and in an ideal world i would say just replace everything but i cant afford to do this so im trying to understand the codes so i can try and narrow down the problem any help would be great many thanks kev Quote Link to comment Share on other sites More sharing options...
chrismar Posted January 20, 2013 Share Posted January 20, 2013 first off fix the leak as this is the most likely cause of the pressure related codes the p1211 means the rail pressure is incorrect and p0251 the pump is not supplying the correct amonut of fuel. this can be the pump cant keep up because of the leak. once the leak is sorted clear codes and recheck. if codes persist try a fuel filter and leak off test. forget about the p1000 its nothing but seperate the others into 2 areas pressure related and electrical related then focus on each in a methodical manner. i had the same pressure related codes on my tdci 115bhp 54 plate mondeo turns out i have 3 injectors leaking back way to much. leak off test showed injector 1 3ml, 2 35ml, 3 50ml and 4 50ml and this was in a 25-30 second period test conducted by garage so not 100% on timings Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 20, 2013 Author Share Posted January 20, 2013 thanks for your help what could give me the u1039 code Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 20, 2013 Share Posted January 20, 2013 could be anything from muck on the sensor, to a faulty sensor, or just a combination of the other error codes, they can sometimes cause red herrings. Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 20, 2013 Author Share Posted January 20, 2013 dont mean to sound thick but what sensor the cam posision sensor ? Quote Link to comment Share on other sites More sharing options...
TDCiST Posted January 20, 2013 Share Posted January 20, 2013 I got the first and last codes on my old focus every time I had my tuning box on it. Maybe the old owner had one? Long shot but worth mentioning... Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 20, 2013 Author Share Posted January 20, 2013 I got the first and last codes on my old focus every time I had my tuning box on it. Maybe the old owner had one? Long shot but worth mentioning... thanks but he was 70 so long shot lol Quote Link to comment Share on other sites More sharing options...
mintalkin Posted January 20, 2013 Share Posted January 20, 2013 the code relates to missing data in the canbus system, as your car is pre obd2 what reader are you using to get the codes as it might not match up correctley and throw this up. Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 20, 2013 Author Share Posted January 20, 2013 im unsure i had some one check it for me i didnt do it myself Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 21, 2013 Author Share Posted January 21, 2013 right changed the pipe and stoped the leak car runs ok with no fault coming up but is a bit rought in 5 and 6 at low revs could this just clear its self after time Quote Link to comment Share on other sites More sharing options...
TDCiST Posted January 21, 2013 Share Posted January 21, 2013 How do u mean rough? Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 21, 2013 Author Share Posted January 21, 2013 like your in the wrong gear bit juddery if you put your foot down it splutters then goes fine Quote Link to comment Share on other sites More sharing options...
TDCiST Posted January 21, 2013 Share Posted January 21, 2013 Only 5th and 6th, Wonder if its the DMF getting a bit rattly, this would be exaggerated in the higher gears at lower revs Quote Link to comment Share on other sites More sharing options...
kevctr Posted January 21, 2013 Author Share Posted January 21, 2013 yer iv just been out again and it seems to be a bit better Quote Link to comment Share on other sites More sharing options...
djtonymc Posted January 10, 2014 Share Posted January 10, 2014 Modeo 1.8 lx petrol keeps cutting out when turning steeringat first on start up idol goes up and down then it cut out then start up again revs die and give it lots of revs keeps running put it in garage they put a diagnostics on p1018replaced map sensorhad a full service oil changeall filters changed spark plugs - coil pack - new leads idol valve Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 13, 2014 Share Posted January 13, 2014 Hi Tony, Rather than crossing threads, please feel free to create your own thread with your issue. Quote Link to comment Share on other sites More sharing options...
sparkplug1988 Posted January 15, 2014 Share Posted January 15, 2014 You might have a injector thats slowly giving up. . If you get a code saying for example injector 1 above max threshold that's mean the injector has gone over the max amount of pulses that it's serviceable for Sent from my C1905 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
