Fiesta Mk7 / Mk8? Heaters Poor
poor heaters
9 replies to this topic
#1 j200shx
j200shx
    Newbie
  • Pip
  • 1 posts
  • Ford Model: fiesta
Posted 20 January 2013 - 07:58 PM
Hi I have a ford fiesta 2009 shape and was wondering what you all make of the heaters on your car?
mine is the 1.4 tdci and has the manual heating not the fancy climate control,
but for my car to stay at a fairly comfotable temperature and i stress the word comfortable not hot i need to keep the heaters on blower number 3 and red hot anybody else have this problem?
or are all your heater good?
thanks josh
#2 b1g_dav3
b1g_dav3
  • 1,708 posts
  • Name: David
  • Year: 2013
Posted 20 January 2013 - 08:37 PM
Mine gets warm fine, the coldness of the air-con is crap though.
#3 MarkyR
MarkyR
  • 508 posts
  • Ford Model: Ford Fiesta Mk7 Zetec S
Posted 20 January 2013 - 09:08 PM
Love mine! I got the auto air con option and haven't looked back, bar when it cycles every 30 seconds or so the lights dim for a slit second if the cars not under power.
I love getting in at the moment, pressing one button only and I get front and rear demisters and full screen demist on, then turn the auto mode on once it's warmed up.
#4 sambooka
sambooka
    Sam Oglesby
  • 895 posts
  • Name: sam
  • Ford Model: mk7 fiesta tdci zetec s
  • Year: 2011
Posted 21 January 2013 - 08:38 AM
My 1.6 tdci zs only seems to be like that when the cars not moving but once its going its brilliant leave it on setting 1 and about half heat
#5 gwhite73
gwhite73
    Member
  • PipPip
  • 11 posts
  • Ford Model: Fiesta Mk7 - 2012 (1.4 tdci 68)
Posted 21 January 2013 - 11:46 AM
I too notice the same with my 1.4 tdci, I have to have the heat set on maximum and the blowers on at least 2 or 3 to get any sort of decent heating out of it. Perhaps it's the diesels that seem to suffer from this?
In my old Mk6 petrol it would be roasting if you had the heat on full. The air con doesn't seem to blow as cold as it did in the Mk6 either...
#6 StewartM
StewartM
  • 69 posts
  • Ford Model: Fiesta Mk7 1.25 Zetec 3 Door
Posted 21 January 2013 - 07:37 PM
The heater on my 1.25 petrol is good.
I note that using ETIS to check specs, the pre-facelift Mk7 diesels don't seem to have a PTC heater, but I put in the reg numbers of a couple of facelifts with Ecoboost and it suggests they get PTC. I wonder if the facelift diesels will get them as well ?
#7 MarkyR
MarkyR
  • 508 posts
Posted 21 January 2013 - 07:41 PM
Whats a PTC heater?
#8 StewartM
StewartM
  • 69 posts
Posted 21 January 2013 - 08:03 PM
PTC is Positive Temperature Co-efficient. A ceramic based element in the heater unit whose resistance increases with temperature and is to a large degree self-regulating. On a freezing morning you can have warm air 30 secs after start up, hot air by 2 minutes.
Very common on diesels because they take so much longer to warm up and starting to appear on Direct Injection Petrols for the same reason, a lot cheaper than a diesel fired heater and simpler and more energy efficient than a heating element in the coolant. ( Referring to one powered by the car's electrical system after start up, not one which plugs into the mains and can pre-heat the engine.)
#9 MarkyR
MarkyR
  • 508 posts
Posted 21 January 2013 - 08:43 PM
Thanks mate. Sounds like a very good system, wonder if the ST has it??
#10 fnkymnky
fnkymnky
    Newbie
  • Pip
  • 6 posts
  • Name: Steven
  • Ford Model: Fiesta MK7 Zetec S
Posted 23 January 2013 - 12:42 AM
I had issues about a year ago with the heat only blowing when the car was moving - the air would blow cooler when stationary. Took it in for a full service and it seemed to have been sorted!
