Fiesta - Screen Wash Smells Like Rotten Eggs!
#1
Posted 24 January 2013 - 04:12 PM
Any help would be appreciated.
Thanks!
#2
Posted 24 January 2013 - 05:07 PM
You'll likely need to remove the wheel arch liner to get access.
#3
Posted 24 January 2013 - 05:51 PM
Hi Debbie,Hi all. The screenwash in my Fiesta has started to smell pretty bad. Is there an easy way I can drain the water out without having to pump it all out? It looks like I'll have to clean the bottle out but I have no idea how I'm going to do that!
Thanks!
This problem is more common than you may think,
The easiest option is to drain the tank through normal use of the jets.
Then fill the bottle with 500ml of Chef Viniger, yes viniger preferably clear viniger, the same stuff you put on chips.
So pour in to the empty bottle 500ml viniger and top up with hot water, not kettle hot, just tap hot water.
Leave it to stand overnight
Dont use the washer jets until finished.
Next morning; open washer bottle as normal.
Insert garden hose and flush through for around 20 minutes, allowing hose water to flow out the top at pressure.
In effect,
The viniger breaks down lime and scum, built up inside the resivour,
The hose will then flush it all out through the lid,
Instead of it cloging your pipes/jets.
When complete,
Empty resivour via normal use through jets,
And fill tank with some ready mixed screen wash solution.
Please note.
When emptying resivour via pump through jets.
Do not keep jets active for more than 60 seconds without stopping for two minutes to allow pump to cool down.
If you run pump for constant runs, you could break the pump seals resulting in low pressure and 60pounds for a replacment.
Finally,
Wear gloves and wash your hands.
All washer bottles containing water for more than 3 months contain Maleria. FACT
And nobody wants to contract that.
No need to remove bottle or panels.
#4
Posted 24 January 2013 - 06:56 PM
#5
Posted 24 January 2013 - 07:18 PM
True Stef,is it not legionella that can be found in stagnant water? A guy i worked with caught legionnaires disease from just walking past a pumping unit used to remove waste fluid from ships
I got mixed up, botg severe V and D though lol
#6
Posted 30 January 2013 - 09:09 AM
#7
Posted 30 January 2013 - 04:49 PM
Worked a treat as they kill all know bacteria
