Anyone Know What This Part Is Called.
30 replies to this topic
#16 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
Posted 24 January 2013 - 09:30 PM
Then i am at a loss...
Surely its not oil pump??
#17 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 24 January 2013 - 09:35 PM
I have spent hours and hours on google to find where one of the pipe coming out of this strage kit would connect to. I will take some clear photos tomorrow.
#18 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Im not sure to be honest, if you google mondeo mk3 coolant heater you will see the glow plug like device i would expect it too look like
#19 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 24 January 2013 - 09:36 PM
does it smell of fuel or have any traces of coolant or oil?
#20 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 24 January 2013 - 09:54 PM
this part is something to do with oil...thats all i know so far
#21 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 24 January 2013 - 10:11 PM
Yes got to do something with oil.
We managed to get used part and fitted it. Do you know where the pipe shown in red circle connects? picture 2 shows same part broken.
#22 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,366 posts
  • Name: Clive
  • Year: 2007
Posted 24 January 2013 - 11:44 PM
I believe it's an evaporator solenoid valve.
#23 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
Posted 24 January 2013 - 11:54 PM
Whats one of them when its at home?
#24 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,366 posts
  • Name: Clive
  • Year: 2007
Posted 25 January 2013 - 12:05 AM
It leads to an evap (carbon) cannister
#25 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 25 January 2013 - 12:24 AM
thought it would be much easier to look for the main part in order to find which pipe connects to it etc..
#26 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 25 January 2013 - 12:36 AM
Thanks for that. Do you also know what connects to that hole there?
#27 FOCA
FOCA
    Feet On The Table
  • 804 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 25 January 2013 - 07:27 AM
1/
The electric pre-heater (on a mk3 Mondeo ) is alloy, it is a straght "torpedo"-like tube with 3 electrical connectors (for the 3 heaters) it connects between the thermostat 19mm "heater" outlet and the cabin heater, it is located at the front of the floorpan/ scuttle (just about where the drivers' feet are but on the other side of the bulkhead) it is visible with the engine undertray fitted, from under the car.
it helps to warm the water/ coolant before it goes to the cabin heater
Some Mk3s had deisel- burning heaters instead (for cold climates - eg for Scandanavian countries etc) the mk3s always had a over- cooling/ not producing enough heat problem - thats why iv'e fitted an (electronically controlled) electric waterpump to mine (and for other reasons) - ive removed my heater and some of the pipes as part of the conversion (don't need it because the electric waterpump only comes on when the engine is warmed up, and it warms up much quicker )
2/
The charcoal (carbon) evaporation canisters are fitted to petrol cars to prevent (or safely filter) petol/ fumes/ gasses escaping into the atmosphere from petol tanks on petrol cars and still allow the tanks to be vented (its another "emmisions" thing)
Its not really nessesary on a diesel (i think mine has a sealed tank with an "expansion chamber" built in to the top of the tank) but thats never stopped them fitting parts designed for petrol- engined cars onto deisels, that should'nt really be there (eg - EGR valves/ systems)
3/
I think it is the oil cooler/ seperator or an associated component
On the mk3 Mondeo diesel engine, there is a watercooled oil cooler on the bottom/ front of the engine, a small thermostat comes out of the side of the waterpump where it feeds a coolant hose then goes to the cooler/ seperator, there is another coolant hose that returns to the radiator
it is (part of) an oll cooler that uses the engines main coolant/ radiator, controlled by its own thermostat (not like a seperate oil cooler radiator like the ones on a race/ performance car )
so water (coolant) and oil runs through it - there should be a water coolant/ in/out and an oil in/out
Do i get a prize if im right? :)
#28 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 25 January 2013 - 02:28 PM
1/
2/
3/
option 3 looks good to me. I went to ford this morning and they showed me this part on their system but couldn't find me hose coming out of this bit.
#29 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 25 January 2013 - 06:08 PM
showed it to a mechanic who charged me £40 and said this connects to the air filter box but we have just installed the air filter box and there is no such places where this part will connect.
we have one spare hole as pictured. Do these two bits connect together.
this part is connected behind the engine and numbers on it are
PA6-GF35 (matches with other part above)
AV61-9C623-B
N07011C160
N07011C170
#30 charikaar
charikaar
    Member
  • PipPip
  • 25 posts
  • Ford Model: s-max
Posted 25 January 2013 - 06:10 PM
AV61-9C623-B
N07011C160
N07011C170
