Carl_D Posted July 17, 2014 Share Posted July 17, 2014 Hey guys, picked up my focus last week and just sorting out the aux input. Being lazy and not taking the radio out as we haven't got any keys for it, so whipped out the glove box to check if 4 pin connector is there. Found the 6 pin and 4 pin and just want to confirm the aux cable is the 4 pin plug with 2 wires coming off it. Would it be safer just to nip to ford tomorrow and borrow some keys to check the cable is in the back of the radio? Edit: Sorry typo- 3 wires coming off 4 pin plug not 2. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 17, 2014 Share Posted July 17, 2014 Not the correct plug unless the 4 pin has 3 wires off it. Sent from my S5 Quote Link to comment Share on other sites More sharing options...
Carl_D Posted July 17, 2014 Share Posted July 17, 2014 Not the correct plug unless the 4 pin has 3 wires off it. Sent from my S5 Sorry Clive, made a typo. 3 wires coming off 4 pin plug I found not 2 as I stated earlier. Quote Link to comment Share on other sites More sharing options...
ARRIVAMAN Posted August 18, 2014 Share Posted August 18, 2014 You have 4 chooses , (1) Unscrew the inside of your glove-box and you should see the AUX connection if not , (2) Pull out your radio and connect an AUX-3.5MM Jack cable to the harness connection both of theses cables for 1/2 can be bought from amazon for £7 each depending upon which one you need . (3) if you don't fancy fitting cables you can buy a digital FM sender unit for £13 . (4) last but not least replace your Ford cd6000 with either a basic new Sony £40 ,or a 2din all singing and dancing model £95 Some people don't rate the sender unit , I can recommend one which I have used for several years with out any drop in quality or interference , it just depends on how handy you are . Quote Link to comment Share on other sites More sharing options...
Dabbsy Posted October 25, 2014 Share Posted October 25, 2014 I've had my focus for a few months now and I thought my AUX cable was built in. After reading through this thread and looking in the glovebox it seems that the car didn't have a cable as standard and one of the previous owners fitted it? Quote Link to comment Share on other sites More sharing options...
MM92 Posted November 27, 2017 Share Posted November 27, 2017 Hi, I know this thread is old but just got a MK2 and looking at adding a aux from my CD6000. Does anyone know the part number for a cover plate with an aux input to replace one of my blank covers, next to the rear window button? Rather than plugging into a loose cable. Thanks! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 27, 2017 Share Posted November 27, 2017 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F322864003125Check my guide links for how to fit and also make the usb socket into a convenient socket for phone/satnav/dashcam power.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
MM92 Posted November 29, 2017 Share Posted November 29, 2017 Thanks for that. Is there a panel/plate with just a aux input so I can put the aux into the back and then plug in via the panel? Can only see Aux and USB combos. Or can I use that without any USB plug in required? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 29, 2017 Share Posted November 29, 2017 There aren't any just aux ones afaik.I have seen cases of someone creating their own using bolt in sockets though.You don't need to connect the usb but if you wire it up as per my guide then you have a handy usb power socket.Sent from my SM-G930F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Micro Posted November 29, 2017 Share Posted November 29, 2017 58 minutes ago, Stoney871 said: I have seen cases of someone creating their own using bolt in sockets though. I mounted a little button on a grey piece of plastic, which happily stuck in with 3M VHB tape. I didn't really want to drill the actual blank, and the blanks seemed quite expensive! Quote Link to comment Share on other sites More sharing options...
MM92 Posted December 11, 2017 Share Posted December 11, 2017 What's the best/simplest way to take out one of the blank cover plates? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 11, 2017 Share Posted December 11, 2017 Pop it out with a scrrwdriver.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Njd1975 Posted January 6, 2019 Share Posted January 6, 2019 Hi all. Wow...Ive noticed this thread started 5yrs ago, and some great advice has been given.... And yet I still need help🤣. Ok... my Focus quadlock seems to have the Aux wiring in the "C" block, so I believe the Aux cable is in there, but after much swearing and constant searching, the only connection I can find "Hidden" up in the Glovebox is for the Airbag?! Its only 3 wires, but trying to trace them from the quadlock to.... errrr.... god knows where seems impossible as the whole wiring loom is fed upwards and under the I.P. I've got the 3mm jack socket to plug straight in once I can find the damn thing!! Never known such an over complicated, pointless and weird design, and I work for a Car Manufacturer!! Any further help would be much appreciated. Thanks guys Neil Quote Link to comment Share on other sites More sharing options...
Botus Posted January 6, 2019 Share Posted January 6, 2019 how hard did you look? you have the right pins connected for the socket … you have to take out the inner "bucket" of the glovebox to find a tapped up socket that you can then plug in a separate 3.5mm female socket https://www.fordwiki.co.uk/index.php?title=Quadlock_Stereo_Connector_-_Sony_DAB_/_USB http://pinoutguide.com/Car-Stereo-Ford-Volvo/ford6000_cd_pinout.shtml Quote Link to comment Share on other sites More sharing options...
Njd1975 Posted January 6, 2019 Share Posted January 6, 2019 Yes mate. Removed the 7ish torx screws and removed the bucket. Spent ages with my head in there and the only wire taped up out the way is the 6 pin Airbag socket. Already got the 3.5mm female socket.... just no sodding Aux lead to plug into. Tempted to remove the "C" block and just re-wire it from scratch. Quote Link to comment Share on other sites More sharing options...
