Surrinder Posted January 27, 2013 Share Posted January 27, 2013 Hello all. I may have posted before but I cannot recall. The speedometer on my Ford Focus estate V995 NBM 1999 stops working, so I rely on the revcounter, then the speedometer sometimes starts working again. I have the Haynes manual but that only talks about removing and refitting a "vehicle speed sensor" that talks to the ECU and then the Speeddometer. Could this be my solution (replace or refit?). Thank you for reading. Surrinder Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 27, 2013 Share Posted January 27, 2013 new vss its a common problem Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 27, 2013 Share Posted January 27, 2013 +1 The VSS is a known problem area. It misreads and causes the speedo to drop and the odometer won't read the mileage you've done either. Sometimes you'll feel a drop in performance too. A new sensor and mounting pin will be required and is a bit of a pig to get the old one out but is doable. Quote Link to comment Share on other sites More sharing options...
Surrinder Posted January 27, 2013 Author Share Posted January 27, 2013 Thanks. I will try to get hold of a replacement unit before I even try to dismantle/refit/replace the unit. I was going to ask what VSS meant but my little brain clicked ON - vehicle speed sensor. Surrinder Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 27, 2013 Share Posted January 27, 2013 Indeed. eBay do a sensor and pin kit quite cheaply. The new pin is an essential as the old one will fight you and get mangled. Quote Link to comment Share on other sites More sharing options...
