I have recently purchased and 09 SMax with the NX navigation system installed. I could not get it to recognise my phone (Samsung Galaxy S3), however reading throguh the manual, it suggested doing an update via ford-mobile-connectivity.co.uk. I did this and whilst it did not confirm it had completed and turned off about 20 minutes into it, it did display the bluetooth audio option.
I then had an issue with where the guages did not work (even in diagnostic mode, but that is a whole other sotry) and to resolve this I disconnected the battery and whilst this resolved the gauge issue, the bluetooth audio option has now disappeared?
I thought it may ahve just reset back to what it was before and needed me to run the update again, however when I try to apply the update it says update not required. Does anyone have any ideas what I can try?
Where Has The Update / Bluetooth Audio Gone?
Started by philljoynes, Jan 29 2013 12:25 PM
5 replies to this topic
#1
Posted 29 January 2013 - 12:25 PM
#2
Posted 29 January 2013 - 12:31 PM
If I remember correctly, the 09 satnav needed a firmware upgrade (may already be installed on yours) and a change to vehicle settings (via workshop PC/IDS) to enable BT audio. The check for the setting may have been skipped once after your update, and then only been done after the reset (thus disabling the option again).
#3
Posted 29 January 2013 - 06:46 PM
Is your phone still paired. Maybe try pairing again or. even remove paired phone and repair it
#4
Posted 01 February 2013 - 11:10 AM
Thanks for the replys.
I have tried to update the NX to SP 5.3 and this updated, but did not bring back any bluetooth functionality. Interestingly there is a service menu on the NX that is accessed by holding the NAV and Menu buttons for a second and then when you let go it takes you there, to several tests and versions menu.
I have also tried repairing, thanks for the suggestion.
I guess it will be a trip to Ford and hefty wedge. Does anyone konw how much it would reoughly be?
#5
Posted 01 February 2013 - 11:30 AM
To be clear - is your issue with Bluetooth Audio (music playback via Bluetooth), or is all Bluetooth functionality gone? If it's the latter, the handsfree module needs a reset (via fuse or battery reconnect), if this doesn't help, the attempted update probably bricked it.
#6
Posted 01 February 2013 - 11:58 AM
Thanks tomtom70, I can still use and see the options for Bluetooth phone (calls, phone book etc.) however I no longer see the Bluetooth option in the CD/AUX menu? I will try resting the Bluetooth module tonight, just in case and let you know how it goes.
