Changing Rear Brake Drums/front Discs + Pads
18 replies to this topic
#1 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 30 January 2013 - 12:23 AM
Ive got a mk 6 fiesta 03 plate and have just bought new rear brake drums, front discs and pads. Are these easy enough to change yourself or would i be better just leaving it to a garage?
#2 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 30 January 2013 - 12:25 AM
Have the brake drums got wheel bearings already fitted? If not your going to need to get them too
#3 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 12:29 AM
Two minutes and ill check
#4 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 12:31 AM
Yeah they come with the wheel bearings
#5 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 30 January 2013 - 12:32 AM
I take it they are fitted though?
#6 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 12:34 AM
yeah theyre already fitted into the break drums
#7 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 30 January 2013 - 12:44 AM
Well that has saved you alot of hassle for a start lol.
Front discs and pads are a breeze to change - make sure you have a 7mm Allen key though
The rear drums are a bit different - I take it you are changing the shoes too. For these you will need a good size breaker bar, 30mm hex socket and a torque wrench as well as your usual tools. I think the rear hub nut is tightened to 235Nm IIRC
Tbh I'm not sure there is much point in me banging on about how to change discs/pads and shoes/drums, I will more than likely confuse you or mislead you. I would recommend you have a look around on google for a guide for each. Both types of brakes are very similar on any car really with a few exceptions.
I would be happy to try and answer any questions if I can.
Remember to work on one side at a time if you are unfamiliar with the setup as this leaves the other side for reference.
#8 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 12:54 AM
Yeah ive got a haynes manual so im gona give that a read before i even attempt it. Ive never realy changed anything like that myself through fear that im gona put my brakes on at some traffic lights after and just keep going instead of stopping :lol: Im gona give it a bash, having looked at the parts they dont look like they'll be too much hassle to change. Ill have a look at the haynes maual tomorrow if i have any questions ill give you a shout :)
#9 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 30 January 2013 - 01:01 AM
It's the springs that bug me on brake drums. Also be careful when you remove the shoes that the pistons don't push out or you will have a mess with brake fluid and you will need to bleed them.
Other than that, when you put the new shoes in with the adjusters backed off, fit the drum and press the brake pedal a few times, doing this will adjust the shoes to the correct position.
You might also find the old drums are difficult to remove - the shoes will have worn a groove in the drum and adjusted out.
#10 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 01:09 AM
Im used to having to bleed things anyway me being a gas engineer ;) lol where abouts in scotland you from by the way? just noticed your location there
#11 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 30 January 2013 - 01:16 AM
It might be a good time to replace the fluid anyway? Especially after doing all that
I'm from fife so not too far from you lol
#12 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 01:20 AM
Awk aye lol only a few hours haha
#13 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 30 January 2013 - 01:26 AM
The brake fluid was changed not long ago cus I had get my break hoses changed
#14 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 30 January 2013 - 02:30 AM
Roughly 85 miles between us?
Ahh right. I can remember changing 4 brake hoses on a driveway once, covered in 5-6 inches of snow lmao. When I had braided hoses on the focus, one of the front ones had a slight split in it so I had to change them back to the standard ones until I got a new set.
#15 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 02 February 2013 - 01:54 AM
How you getting on with this one Dan?
