Front Seat Removal
4 replies to this topic
#1 jon-v8
jon-v8
  • 41 posts
  • Name: Jon
  • Ford Model: Focus Ghia Estate
  • Year: 2006
Posted 30 January 2013 - 09:57 PM
I'm looking to remove the front seats to give the carpet a deep clean, but just want to check how to disconnect the wiring.
I take it it's just a case of disconnecting the battery for 15-20mins, then unplug?
Some have said either don't turn the ignition on throughout the removal/refitting, or disconnect the battery for up to an hour?
Also, is it a T50 Torx for the bolts?
#2 Preee
Preee
  • 3,052 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3
Posted 30 January 2013 - 10:01 PM
Yes disconnect the battery just incase you trigger the Seat airbags , which is the case for the steering wheel but just play safe if you want to remove the seat , not sure of the size of the torx but that sounds pretty close T50
#3 gforce
gforce
    Serial Poster
  • 482 posts
  • Name: Gary
  • Year: 2005
Posted 31 January 2013 - 09:33 AM
As Pree said, disconnecting the battery is always the safety option. You'll obviously need your radio code and to reset electric windows etc when you plug back in.
And to confirm, yes it is definitely a T50.
#4 STEADS
STEADS
  • 402 posts
  • Name: NEIL
  • Ford Model: FOCUS 1.8 TDCI TITANIUM AND 2.0 TDCI
  • Year: 2009
Posted 31 January 2013 - 01:55 PM
Word of acvice tape up the sharp edges on the runners as you will slice the plastic trim getting them in and out if you catch the trim take it from me also the connectors under the seat will only go back in the same position when reffiting just in case you forget where they went.
#5 jon-v8
jon-v8
  • 41 posts
  • Name: Jon
  • Year: 2006
Posted 31 January 2013 - 07:16 PM
Cheers for the replies guys!
I had a feeling it was the same procedure for the seats as the steering wheel.
Gary, good call about the radio code. I have the sat nav in mine, but don't have a code for it??
Neil, been there, done that too! :unsure:
