astings
Sony Gen2 Bluetooth
Hi
I have a mk2 focus, with voice steering control, bluetooth module 7m5t19g488-ad in the glovebox and a sony gen2 head unit, when i press the phone button on the unit it only mutes the audio,for some reason i cannot connect my phone via bluetooth, i have tried resetting the system by
1: removing fuse 112 &
2: disconnecting the battery
I have to re enter my radio code after doing this, but my stored stations are still remembered in the head unit and still no bluetooth
Any ideas please
Are you sure your car has bluetooth?
You should be able to enter the reg/vin on www.etis.ford.com that will give you a readout of what is included on your car.
I believe, if the phone button only mutes the audio, then you do not have bluetooth.
Thanks for your replys guys, just seems odd that there's a bluetooth module and voice on the radio stalk.
but if it isnt bluetooth enabled, there's not a lot i can do
Ford etis says
bt/vc interface only
8 series radio Speakers with telephone prep pack design b
Less cell phone interface system
Voice activated module - British with column stalk control
Very strange.
Done a bit of reading up on it and it seems like you have all the hardware but sometimes the car's software needs reminding it is all fitted.
Have you ever head the bluetooth working? Might be worth seeing if your local dealer can shed any light on the matter.
Thanks Alex, I've only had the car a few months and its not worked since then, will try my local dealer.
Thanks again
