Upgrading Tyres
#1
Posted 03 February 2013 - 07:32 PM
I have 205/40/17 on the fiesta at present, do you know if 215/40 17" would fit on the rim without any issues?
Thanks in advance
#2
Posted 03 February 2013 - 07:46 PM
Guys
Thanks in advance
Yes, it will fit, but i believe it is regarded as bad practice because the tyre will be a little wide for the rim, 215s and 205s should not be fitted on the same axle
#3
Posted 03 February 2013 - 07:57 PM
#4
Posted 03 February 2013 - 08:21 PM
#5
Posted 03 February 2013 - 08:25 PM
#6
Posted 03 February 2013 - 08:33 PM
Turning circle I can understand and would cause the edges to scrub a bit but not sure why it would interfere with te speedo the alloy size is the same,the height 40 is, so the only difference will be the width.
Silly as it sounds I was going to fit them to the rear only, fitted 20mm eibach spacers all round but back could do with coming out a fraction more so instead of buying another set of rear spacers 25mm, as the front tyres need replacing soon that would be the solution?
#7
Posted 03 February 2013 - 09:20 PM
I also thought that when I first read the comment, then remembered that 40 means 40% of the width, so there will be a slight difference....but not sure why it would interfere with te speedo the alloy size is the same,the height 40 is, so the only difference will be the width.
#8
Posted 03 February 2013 - 09:37 PM
#10
Posted 03 February 2013 - 10:38 PM
#11
Posted 04 February 2013 - 12:05 AM
You're just paying out pointlessly.
