Driver Window Issues
5 replies to this topic
#1 Peange
Peange
  • 105 posts
  • Name: Scott
  • Ford Model: Fiesta 1.6 TDCI Zetec S
Posted 05 February 2013 - 03:29 PM
Hi all,
Having a wee problem with my window. Well two really but they're probably connected. The window winds down automatically perfectly, but when closing it I have to hold the switch up until it reaches the top. Also, the window doesn't close fully on the first attempt, it has a tiny gap at the top towards the front, and a slight noise like it's hitting off something. The window can be fully closed by pulling the switch up again.
Help is appreciated as usual!
Scott
#2 sambooka
sambooka
    Sam Oglesby
  • 895 posts
  • Name: sam
  • Ford Model: mk7 fiesta tdci zetec s
  • Year: 2011
Posted 05 February 2013 - 03:48 PM
Cant remember the procedure for teaching your windows but try this turn key to point 2 and Once the window is at the very top pull the switch up like you want it to go up automaticaly and hold it up for 10 seconds that should sort it
#3 Peange
Peange
  • 105 posts
  • Name: Scott
Posted 05 February 2013 - 03:56 PM
Cool thanks man, I'll give that a try!
#4 alexp999
alexp999
    Serial Poster
  • 462 posts
  • Name: Alex
  • Ford Model: Focus 2.0 TDCi Titanium X
  • Year: 2012
Posted 05 February 2013 - 04:18 PM
Reset procedure from when I had a similar problem:
it may require reseting
use the up button untill window is fully closed, release the button for 2 seconds and then hold the button in the up position for 5 seconds, this usually resets the window one touch.
#5 Luke Fletcher
Luke Fletcher
  • 84 posts
  • Name: Luke
  • Ford Model: Fiesta Style +
  • Year: 2009
Posted 05 February 2013 - 04:34 PM
hey,
i had this issue and did roughly the same but i opened the window all they way holding the button and once its all the way down continue to hold the button till it clicks, about a seocnd or two, then the same closing the windows . should sort it out then. thats what mine did and worked fine form then on
Luke
#6 Peange
Peange
  • 105 posts
  • Name: Scott
Posted 06 February 2013 - 01:30 PM
Worked a treat! Thanks guys
