Loud Squeaking Noise Coming From My Car, What Could It Be?
#1
Posted 06 February 2013 - 04:49 PM
I started my car this morning and there was a noticable squeak coming from it. I reversed down my drive and it became a little louder. At this point decided it probably wasn't a good idea to use the car so drove back onto my drive and the squeaking noise became very loud.
Does anyone know what this could be?
I own a Ford FIesta Finnese 53 plate, there are 34,000 miles on the clock.
Had been working perfectly to my knowledge the last few days, came on very suddenly!
Thanks for any help
#2
Posted 06 February 2013 - 04:56 PM
#3
Posted 06 February 2013 - 04:57 PM
This usually isn't much to worry about but worth getting a new belt or the tensioner tightened..
Without hearing it I can't add much more
#4
Posted 06 February 2013 - 05:34 PM
#5
Posted 06 February 2013 - 05:37 PM
#6
Posted 06 February 2013 - 06:27 PM
#7
Posted 06 February 2013 - 06:28 PM
#8
Posted 06 February 2013 - 06:31 PM
#11
Posted 06 February 2013 - 06:55 PM
I think Preee's suggestion of a broken spring may be correct
#12
Posted 06 February 2013 - 11:10 PM
#13
Posted 07 February 2013 - 03:03 PM
I have just spoken to my local mechanic who has had a look and as you all suggested it is a broken spring. So I should now be having it towed to his garage and fixed tomorrow.
Thanks again
Emily
#14
Posted 07 February 2013 - 03:43 PM
#15
Posted 07 February 2013 - 03:47 PM
Looks like a Spring or Shock Absorber might have gone, try pushing the front down a bit if it moves and returns to its current position quickly it will be the spring, if you have the road side jack in the boot or another jack you could just lift that corner up, if its the spring it will keep in contact with the ground for a lot longer than usual and probably a piece of the broken spring will fall out, i just had a front spring go, took the fiesta to get a new cam belt, just as i parked it outside the garage and got out it went ping and dropped down like that, if it happens to be the spring just make sure to have both fronts changed otherwise you wont ride exactly level and the other side may break as well
Good advice. I didn't know of this at the time until mine went. my spring snapped a few weeks back so I only changed the one that broke. Needless to say about a week or 2 later the other side went. Apparently it's a common fault on the fiesta for the springs to go??
Also tagged with one or more of these keywords: squeaking noise, ford fiesta
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Care For Ford FiestaStarted by Imran, 18 Dec 2012 |
Ford Fiesta Club →
Problems With Ford Audio System - Ipod ConnectivityStarted by HProth, 04 Oct 2012 |
Welcome to Ford Owners Club →
New Member Introductions →
Car Newbie HereStarted by Mrmark941, 15 Aug 2012 |
Ford Fiesta Club →
Help Needed With Ford Fiesta 2001 Mk5 Speakers! :)Started by matthewscott92, 18 Jun 2012 |
Ford Fiesta Club →
Ford Fiesta Annual Maintenance ServiceStarted by MisterC, 24 Jan 2012 |
