Egr Blank Fitted 1.8 Tdci 08 Plate
55 replies to this topic
#31 FOCA
FOCA
    Feet On The Table
  • 844 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 02 March 2013 - 05:00 AM
all fitted :D
thought the throttle does feel a bit better, but tbh its probably just a placebo because i read it on here!
Cheers
LOL, should help it pick up a bit better from low revs, eliminate the "EGR flatspot", and yes, the throttle can feel a bit more responsive, its not a usually massive difference, (depends on the car) they recon you need a 10% power increase to have a noticable increase in power, you might see a (slight) difference with a stopwatch or on a dyno
As Sal has said, the main thing is the inlet/ EGR housing no longer gets contaminated
Cleaning out the inlet manifold and EGR and resetting the ECU may give more noticable gains (especially if the inlet is badly choked up with carbon/ gunge from the EGR)
 Theoretically there should be a slight increase in MPG as well, it would be good to get feedback/ figures about that
#32 IINexusII
IINexusII
  • 68 posts
  • Ford Model: Focus 1.8 TDCI Zetec Climate
  • Year: 2006
Posted 11 March 2013 - 08:44 AM
Done mine on Saturday, i can definitely feel an improvement on lower revs :D wasn't too hard to do just be careful that the wiper arms are aligned correctly.
driven about 120 miles since, no EML yet (Euro4 engine). MPG also seems unaffected, if not then i would say it is slightly better, a406/m40/a40 from east london to cheltenham with a few of full throttle takeoffs and overtaking and managed 56MPG, and i would normally get that amount with granny driving
#33 b1g_dav3
b1g_dav3
  • 1,719 posts
  • Name: David
  • Year: 2013
Posted 11 March 2013 - 10:40 AM
Hmm reading this I'm considering doing it on my Fiesta 1.6 TDCi, only thing is I don't really want to end up with and fault codes coming up >.<
#34 Aldoo
Aldoo
  • 103 posts
  • Ford Model: 1.8 TDCI Focus Sport
  • Year: 2006
Posted 11 March 2013 - 10:31 PM
i dont think any of us have had any error lights so far mate
i posted here on the 1st, so i would guess iv done a good few hundred miles now without any lights. and iv not done a mpg test yet, but it wouldnt be accurate in the weather we're having ATM anyway
#35 b1g_dav3
b1g_dav3
  • 1,719 posts
  • Name: David
  • Year: 2013
Posted 12 March 2013 - 02:04 PM
If I do get an error and remove it, problem solved or will it end up going in to limp mode? -.-
#36 FOCA
FOCA
    Feet On The Table
  • 844 posts
  • Name: FOCA
  • Year: Non
Posted 12 March 2013 - 03:52 PM
Won't cause limp mode, limp mode and error codes are different things
So far no-one has even had an EML on yet, and several forum members have fitted a solid plate, with only positive/ good results -
I think you are pretty safe fitting one (solid, stainless steel blanking plate)
#37 Mike77
Mike77
  • 506 posts
  • Name: Mike
  • Ford Model: Focus 1.8 TDCI Titanium
  • Year: 2006
Posted 12 March 2013 - 05:57 PM
Still no light on mine, done a good few miles since fitting, touch wood all is good :-)
#38 salsheikh
salsheikh
  • 885 posts
  • Name: Sal
Posted 12 March 2013 - 07:51 PM
no light here either, all good under the hood!
#39 b1g_dav3
b1g_dav3
  • 1,719 posts
  • Name: David
  • Year: 2013
Posted 13 March 2013 - 02:27 PM
Will the fact it's a Euro 5 engine make any difference? Was reading I need one with a hole in or something >.<
#40 FOCA
FOCA
    Feet On The Table
  • 844 posts
  • Name: FOCA
  • Year: Non
Posted 13 March 2013 - 02:34 PM
Where did you read that? - the ones with the hole are useless -  its a blanking plate not a mint :lol:
#41 baitman
baitman
  • 36 posts
  • Ford Model: Mondeo 2.0 tdci estate
  • Year: 2005
Posted 13 March 2013 - 02:50 PM
:D
#42 leftathome
leftathome
    Member
  • PipPip
  • 11 posts
  • Ford Model: Focus 2.0dtci Ghia estate
  • Year: 2007
Posted 13 March 2013 - 04:20 PM
Oh,how I miss humour !!!!!!!!!!!!!!!!!! :D
#43 b1g_dav3
b1g_dav3
  • 1,719 posts
  • Name: David
  • Year: 2013
Posted 13 March 2013 - 06:58 PM
Yeah, just restricts rather than blocks due to the fact the EGR need air going through it >.<
Seeing it's just a code, may as well just do it and see, if it throws a fault I'll just get it knocked off come service time.
#44 IINexusII
IINexusII
  • 68 posts
  • Year: 2006
Posted 25 March 2013 - 01:06 PM
I might be considering removing mine soon... ive started noticing this "wawawawawaw" type sound everytime i get over 40mph, it should be sealed tight around the blanking plate area. did you guys remove that thin gasket when fitting the blanking plate?
#45 Mike77
Mike77
  • 506 posts
  • Name: Mike
  • Year: 2006
Posted 25 March 2013 - 01:49 PM
Yes
