i left the thin gasket in, and installed the egr blanking plate on the left of the gasket, so the egr plate was nearer the egr. this allows the thin gasket to make the seal on the pipe from the manifold, as intended.
Egr Blank Fitted 1.8 Tdci 08 Plate
#46
Posted 25 March 2013 - 02:29 PM
#47
Posted 25 March 2013 - 03:17 PM
#48
Posted 25 March 2013 - 04:19 PM
ill remove the gasket then and see if that makes any difference
#49
Posted 25 March 2013 - 06:13 PM
Varied opinions on this then, as most have removed the thin plate and just replaced it with the blank. No problems/leaks with mine.
its not that i thought it still needed the gasket, its just that the blanking plate i bought had cut away lugs so you only have to loosen the bolts to fit it rather than remove them fully. my EGR had been cleaned prior to me ordering the blanking plate.
if i had to remove them, as when having to clean the EGR, then i would have also had to remove the gasket.
its so thin im sure it makes no real difference if blanking the EGR.
#50
Posted 25 March 2013 - 08:44 PM
i removed mine too. are you sure there isnt any leaks that are making the noise?
#51
Posted 25 March 2013 - 08:57 PM
anyone else noticed more smoke with this?
only on start up though, so i dont know if its just the extra cold we're having recently ..not a problem in the slightest because it does seem to be driving better and better MPG, was just wondering
cheers
#52
Posted 25 March 2013 - 09:42 PM
i do get smoke on very cold starts, thats just my glowplugs needing replacing, so i wouldnt worry about it if its just on cold starts
@salsheikh ill have to give it a look on the weekend, its way too cold to do anything right now ![]()
#53
Posted 25 March 2013 - 10:12 PM
I might be considering removing mine soon... ive started noticing this "wawawawawaw" type sound everytime i get over 40mph, it should be sealed tight around the blanking plate area. did you guys remove that thin gasket when fitting the blanking plate?
All the gasket does is seal the two faces where the blanking plate is fitted, many remove this, its usually made of stainless steel and is "sprung" to help seal the two faces, when you put the blanking plate on, you can choose to put the gasket on the exhaust side of the blanking plate or the inlet side,
i would favor the exhaust side, and a little instant gasket in a ring around the inlet side
ideally, you want 2 gaskets - 1 on each side of the blanking plate.
Aluminium ones are soft and act as a gasket itself , but i dont favor them because they can sometimes melt
If the exhaust side was leaking it might make a noise like a blowing exhaust
if the inlet side was leaking it might make a noise like a hissing sound , theoretically this could lose boost and cause additional smoke, or make the turbo have to work harder,
Smoke - Also there are lots of other reasons for an engine producing extra smoke (eg - glowplugs) other than the blanking plate leaking - and not every noise the car makes is because the EGR is blanked, just because it was done recently
The only thing you can be sure of is a properly fitted solid blanking plate will "fix" a faulty EGR valve and stop the inlet being contaminated with carbon.
And is unlikely to cause problems apart from the EML coming on in some Euro 4/ 5 cars
#54
Posted 29 March 2013 - 02:39 PM
I fitted an egr blank last night, then took it out this morning. It triggered the MIL within 10 miles. Not a problem in it self, but I don't want it to mask any other "proper" MIL , which if not attended to in good order could cause lots of damage. So then I fitted my boost gauge! Sweet.
Should have said, it's Euro 4 Diesel.
#55
Posted 29 March 2013 - 05:13 PM
Thats interesting - your the ist one to report this, and other (late model euro 4)Focus owners have fitted solid plates
Many Euro 4 Mondeo owners also trigger EMLs (engine management light(s)) but prefer to run their cars with a solid EGR blanking plate, because of all the advantages
Many just reset/ check their fault codes once a week and otherwise let the light stay on
The EML can "cry wolf" and go on for no reason (eg fitting a blanking plate) or serious engine damage can occur without it coming on (eg - running the engine driy of oil and siezing it / "writing the engine off") so its of limited value
Didn't a member on the forum snap his turbo in half without the EML coming on?
I wish it did but the little light on the dash coming on (or not
) is not goibg to protect your engine
#56
Posted 29 March 2013 - 06:20 PM
Code was P0405 EGR Sensor A Circuit Low, which makes sense.
