Someone kindly scratched my car the other week and its quite a deep one, was just wondering if anyone could recommend a good scratch remover or will i have to flatten it back with wet and dry and lacquer it again?
Has it gone down to the primer and can you feel it it you run your fingers across? , if its not dow to the primer you may get away with masking it and spraying laquer then cut it bac with wet n dry and then polish it out.
Somebody did the same to mine! used a laquer pen and went over it a couple of times its better but you can still see it,btw that black strip down the door will hold water leading to rust id remove it good luck .
