steesh Posted February 9, 2013 Share Posted February 9, 2013 Someone kindly scratched my car the other week and its quite a deep one, was just wondering if anyone could recommend a good scratch remover or will i have to flatten it back with wet and dry and lacquer it again? Picture attached. Cheers Quote Link to comment Share on other sites More sharing options...
Preee Posted February 9, 2013 Share Posted February 9, 2013 Has it gone down to the primer and can you feel it it you run your fingers across? , if its not dow to the primer you may get away with masking it and spraying laquer then cut it bac with wet n dry and then polish it out. Quote Link to comment Share on other sites More sharing options...
steesh Posted February 9, 2013 Author Share Posted February 9, 2013 Dont think its gone down to the primer but its close Quote Link to comment Share on other sites More sharing options...
MrRedman Posted February 10, 2013 Share Posted February 10, 2013 Somebody did the same to mine! used a laquer pen and went over it a couple of times its better but you can still see it,btw that black strip down the door will hold water leading to rust id remove it good luck . Quote Link to comment Share on other sites More sharing options...
Preee Posted February 10, 2013 Share Posted February 10, 2013 You may get away with laquer and fine wet and dry and a polish Quote Link to comment Share on other sites More sharing options...
