Thank you
Interior Lighting Help (Mk3 Focus 1.8 Tdci)
#1
Posted 10 February 2013 - 12:50 PM
Thank you
#2
Posted 10 February 2013 - 12:56 PM
Your car is a Mk2.5 as we call it.
#3
Posted 10 February 2013 - 01:10 PM
#4
Posted 10 February 2013 - 01:22 PM
#5
Posted 10 February 2013 - 01:31 PM
#6
Posted 10 February 2013 - 01:35 PM
#7
Posted 10 February 2013 - 01:39 PM
#8
Posted 10 February 2013 - 02:00 PM
http://www.ebay.co.u...=item4aa6e1f1c1
or you can search for the SMD LED strip type which you can cut down to any length
#9
Posted 10 February 2013 - 02:03 PM
#10
Posted 10 February 2013 - 02:23 PM
Yeah I was looking at SMD LED strips, quite cheap and easy to install. Not sure whether to get green or blue though. Final question (hopefully), if I pop down to the scrap yard a pick up a button (switch) for the demister panel is it quite easy to pop in it?
Yes very easy to pop in , using a tiny flat screw driver you can pop out the spare blanks , run your wiring , check it all works and then push in the switch . Removing a Switch on the other hand you have to actually get the panel out as they fit a lot tighter and clip in.
using a multimeter you can which pins on the switch will work for the wiring , you can also loop off the interior lighting of the other switches to light the switch up the same.
Only thing i can't remember is if the switch "acts" like a normal type switch , meaning i'm sure they work on signal switching , or pulse switching .So pressing sends a pulse to the GEM which switches the part on/off , so the heater switch may not be any good to use as a normal switch.
#11
Posted 10 February 2013 - 02:35 PM
#12
Posted 10 February 2013 - 02:39 PM
before buying a switch test one of your heater switches and see if i'm correct about them not being a standard switch type , could save you some money buying one.
If you look through my guides below , they will tell you how to get to the switches to get them out.
#13
Posted 10 February 2013 - 02:51 PM
#14
Posted 15 February 2013 - 10:08 AM
#15
Posted 15 February 2013 - 02:38 PM
Also tagged with one or more of these keywords: lighting, help, switch
Welcome to Ford Owners Club →
New Member Introductions →
New Memeber - New ProblemStarted by danskihill, 16 Jun 2013 |
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Remove / Replace Wing Mirror CoverStarted by PaulHigson, 12 Jun 2013 |
Ford Fiesta Club →
Mk4 Fiesta Zetec S Clutch Change. Quick Reply Please!Started by JacobOsborne, 10 Jun 2013 |
Ford Fiesta Club →
Fiesta Zetec S 11 Plate Help!Started by BennieFaeDenny, 07 Jun 2013 |
General Ford Discussions →
Escort VanStarted by t9swc, 05 Jun 2013 |
