Central Locking Not Working!
15 replies to this topic
#1 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
  • Ford Model: Fiesta MK6
Posted 10 February 2013 - 02:46 PM
I bought a 2004 fiesta finesse 5 door yesterday and the central locking isn't working so I got it cheap. When I unlock the drivers door there is no noise of the motor unlocking the other doors and they do not open unless opened using the key or from the inside.
I was thinking it could be a fuse, broken wires or bust motor?
Does anyone have any advice of what to do?
Cheers Callum
#2 Preee
Preee
  • 3,060 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3
Posted 10 February 2013 - 02:57 PM
Got to be worth checking electrical side first , i.e fuse's , is it remote?
#3 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
Posted 10 February 2013 - 03:32 PM
No, well it might be when I bought it it only came with one key and it isnt a fob key. Its the bottom of the range but it might still have had a fob on the main key.
#4 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
Posted 10 February 2013 - 03:35 PM
Also where is the fuse box located on a fiesta mk 6?
#5 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 10 February 2013 - 11:29 PM
It might be the actual key theres 2 ways you can set the key up one so that it only opens and locks the drivers door unless you press it about3 or 4 times and the other where it opens all the doors. Im sure you have to hold the lock button on the key for about 10 seconds or something and this changes the settings. Ill go and check in a minute and let you know.
#6 Mordey
Mordey
  • 113 posts
  • Ford Model: 2010 Fiesta zs
Posted 11 February 2013 - 02:38 PM
Have a look for the options in the menu.
Also found this. might be of no good to you though as you dont have a fob key;
"Take your car remote and press the door unlock and lock buttons simultaneously for at least 4 seconds with the ignition off.
The direction indicators will flash twice to indicate that the unlocking function has been sucessfully re-programmed.
Pressing and holding both buttons simultaneously for at least four seconds again will change the function back"
Thanks to igglepiggle for this
#7 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,274 posts
  • Name: Daniel
  • Year: 2003
Posted 11 February 2013 - 02:42 PM
Thats what I was on about :) didnt have chance to check my owners manual last night
#8 Nathan_M
Nathan_M
  • Members via Twitter
  • 196 posts
  • Name: Nathan
  • Ford Model: Fiesta Flame Mk6
  • Year: 2004
Posted 11 February 2013 - 08:01 PM
You only have the master key so have no buttons to press, have you tried holding the key when you unlock it, that might be the way otherwise it must be electrical because i doubt 3 door lock motors have gone, wondering if you have tried unlocking the boot lid with the key rather than then button on the dash as i would have thought the boot lock work with the door locks.
#9 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
Posted 11 February 2013 - 08:34 PM
I don't have the key buttons to open the booth that way, i tried the button on the dash and that does not work either? i looked in the fuse box and fuse F24 has a padlock next to it and doesnt have a fuse in its slot?
#10 Nathan_M
Nathan_M
  • 196 posts
  • Name: Nathan
  • Year: 2004
Posted 11 February 2013 - 09:35 PM
Just out of interest is there a light that flashes when the engine is off that looks like a car with a padlock infront of it? And also when you lock it do the indicator lights flash?
#11 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
Posted 11 February 2013 - 09:51 PM
Yep theres a red padlock dash board light that flashes and no the indicators dont flash when its locked.
#12 Nathan_M
Nathan_M
  • 196 posts
  • Name: Nathan
  • Year: 2004
Posted 11 February 2013 - 11:20 PM
If you hold it when you lock it does it deadlock or just single lock, and im not sure on fuse numbers but if the car has central locking and that is the fuse for the system then it would be interesting to know why it was removed in the first place, i have a feeling though that the fuse that operates the locking is on the same fuse as the immobiliser, and if thats working then why wouldn't the locks, i would say that the fuse with the padlock is for an alarm which you dont have, have a look for te wiring looms going into each door to see if they are broken or disconnected, if i remember i will get the book out tommorow and see what it says about fuses.
#13 Dan62
Dan62
  • 236 posts
Posted 12 February 2013 - 08:49 AM
F24 (20A) is for the locking system which is why the central locking doesn't work.
It was probably removed because you have a bad central locking motor.
FYI If you have a key hole on the passenger door to lock/unlock, you don't have remote central locking.
#14 Cpemble
Cpemble
    Newbie
  • Pip
  • 7 posts
Posted 13 February 2013 - 05:19 PM
Thanks allot, new fuse is in central locking works! But the driver side door wont open all the doors but the passenger side will. I guess the solenoid or wiring is damaged? What do i need to look for?
#15 Dan62
Dan62
  • 236 posts
Posted 13 February 2013 - 05:41 PM
Ok, so its the lock/unlock switch in the drivers door or its wiring that's the problem. You can check the switch out if you have a mulitmeter ? ... Does the door ajar light come on when the drivers door is open ? The switch contacts on the actuator are Pin 1 (Normally open contact) and Pin 6 (common). Having browsers problems here !
