csmith10 Posted February 10, 2013 Share Posted February 10, 2013 Hi I have an 08 Focus 1.6tdci which decided to die on my Thursday morning. The problem which has developed is that the engine will completely shut down under acceleration. It first happened accelerating out of a 30mph zone. There was no warning just cut off. I turned the ignition off and on and it came back to life and allowed me to carry on under light throttle loads but would shut Down again when applying any kind of throttle. I have plugged the car into my laptop and no faults are logged and there is no MIL light on. Is this a known fault? Or has anyone experienced this before? Any help would be greatly appreciated Cheers Chris Quote Link to comment Share on other sites More sharing options...
csmith10 Posted February 11, 2013 Author Share Posted February 11, 2013 No ideas? Cheers Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 11, 2013 Share Posted February 11, 2013 When was the fuel filter last changed? Quote Link to comment Share on other sites More sharing options...
csmith10 Posted February 11, 2013 Author Share Posted February 11, 2013 I'm not sure, I have only had the car 3 months and it came with full history as it was an ex fleet car Cheers Quote Link to comment Share on other sites More sharing options...
IINexusII Posted February 11, 2013 Share Posted February 11, 2013 Any diagnostic codes? Quote Link to comment Share on other sites More sharing options...
csmith10 Posted February 11, 2013 Author Share Posted February 11, 2013 No, nothing, plugged into my laptop and I did a self diagnostic but no codes stored Cheers Quote Link to comment Share on other sites More sharing options...
jimmy182 Posted February 11, 2013 Share Posted February 11, 2013 Not much to go on but could likely be fuel restriction in the filter. Quote Link to comment Share on other sites More sharing options...
Andy H Dibley Posted February 11, 2013 Share Posted February 11, 2013 Do the filter as a first port of call. Only a cheap item. Only thing is, it sounds like a computer issue if its shutting down repeatedly. Can you get it to do it while stationary or does it only happen when moving? Quote Link to comment Share on other sites More sharing options...
csmith10 Posted February 12, 2013 Author Share Posted February 12, 2013 Just when moving, although it does seem sluggish to rev when stationary. Wouldn't a computer issue throw up a fault code? Cheers Quote Link to comment Share on other sites More sharing options...
Andy H Dibley Posted February 12, 2013 Share Posted February 12, 2013 See a fuel filter you'd expect to throw up a code to, insufficient fuel pressure or whatever it is. Still, if it were me and you're hands on, remove the fuel pump fuse, run the engine till it dies, change fuel filter, re-install fuse, remove airbox lid, change element, see if there's any improvement. Sure there's no whooshing noises or that coming from the bay? Quote Link to comment Share on other sites More sharing options...
csmith10 Posted February 12, 2013 Author Share Posted February 12, 2013 No noises from the engine bay! I did notice the fuel economy drop over the last couple of months. It's steadily gone down from 55mpg to 49mpg with no change in driving style. Cheers Quote Link to comment Share on other sites More sharing options...
willywonker Posted March 15, 2013 Share Posted March 15, 2013 I have a 2005 ex fleet focus 1.6 tdci and getting same issues as what you are describing. Did you get any resolve on yours. Diagnostics cam back with a few error codes so I changed the EGR Valve, Cam shaft sensor, Crank Shaft sensor, New fuel filter and still no joy. Car would start fine and go about town when engine is cold but when it is up to operating temperature, rev it past 2.5k revs, engine would splutter and die out. It does not do it when cold, only when engine is warm. It will not restart when it stalls. To get it to fire up, I have to lift the bonnet, slam it down and it will restart and continue with my journey. I am going to replace the fuel pump relay and see if that might play a part. It seem the failure is heat related and when it gets up to temperature, the contact goes further apart hence causing it to stall. Quote Link to comment Share on other sites More sharing options...
csmith10 Posted March 17, 2013 Author Share Posted March 17, 2013 Hi Sorry for the late reply, I ended up getting the fuel pump replaced under warrantee Cheers Quote Link to comment Share on other sites More sharing options...
