Escort Mk 6 97 R Reg 1.6 Zetec Rough Tickover/idle Issue
#1
Posted 10 February 2013 - 07:37 PM
#2
Posted 10 February 2013 - 08:02 PM
#3
Posted 11 February 2013 - 08:06 AM
#4
Posted 13 February 2013 - 10:18 PM
I'd clean the MAF, clean the ICV and check for any split vacuum pipes or the common pipe collapsing on the elbow.
#5
Posted 14 February 2013 - 11:14 AM
#6
Posted 14 February 2013 - 06:38 PM
#7
Posted 17 February 2013 - 10:37 AM
#8
Posted 21 February 2013 - 09:09 AM
#9
Posted 26 February 2013 - 09:28 PM
#10
Posted 01 March 2013 - 10:02 PM
the most common reason ive come across for hunting idle is its drawing air somewhere...
the elbow is part of the breathing system, from memory, been a while since worked on these escorts, might be 2 of them, both on right hand side of cylinder head, just follow the breather pipe from pcv valve thats fitted on front of engine as you look at it.
pcv valve itself is a common reason, plus had a few that pull in air around the rubber seal that the pcv sits in....
easiest test for checking if pulling in air is spraying wd40 [better still, carb cleaner if your careful as its flammable) while engine is running...when you spray across an air leak, you will hear a change in idle....always best to do this whilst engine is hunting.
#11
Posted 02 March 2013 - 05:56 PM
ok..cheers. wase.....il try & get that fitted monday..its driving me nuts..but today it was ok..typical..il grab some more hooky wd40..as its cheaper at wickes..& get spraying..il report back ..on mon..
any ideas where i can get a cheap quote for a blowover on my escort cabby in zinc yellow..the paints sun faded..laquer is peeling off the bumpers & rear spoiler...preferably in essex herts ...the paint is o/e ..so should be ok..cheers jim..
#12
Posted 02 March 2013 - 08:03 PM
another common area, whilst you got wd out, give the throlle body/butterfly a clean...safest way is wd on a tissue, open throttle wide and wipe round where butterfly sits when closed, keep doing it till tissue stays clean....dont use carb cleaner or similar as the throttle body has a coating that can be destroyed...
#13
Posted 10 March 2013 - 02:01 PM
thanks again to all who posted..i went to ford & bought the 90 degree replacement breather pipe off the back of the manifold..as .ive replaced everything else...£14..all done now & the car is a lot better..no black smoke from the exhaust..& im back up to around 30 mpg round town..the old pipe was crushed as expected..& was chamfered/rubbed at one end..it was goosed....& ive ordered some aerosols of zinc yellow to do both my bumpers,spoiler & boot..when its up to doubble figures anyway..cheers..
#14
Posted 10 March 2013 - 05:56 PM
quick tip, keep your old sensors, sometimes, when it comes to various sensors dotted round the engine, you get what you pay for..there are a lot of cheap, in price and quality, sensors on the market
#15
Posted 12 March 2013 - 07:31 AM
GGRRRRRRRRRRRRRRRR..TALK OF THE DEVIL & SURE HE WILL APPEAR..GUESS WHAT... ALL WAS WELL UNTIL YESTERDAY..I JUST HAD A NEW DAB HEAD UNIT FITTED YESTERDAY AT HALFORDS..ALL OK..UNTIL I PULLED OUT THE CAR PARK...TO GET UP THE HILL..THEN BANG..BBRRRRRM..BBRRRRM..THE UGLY IDLE ISSUE ROSE ITS HEAD AGAIN..THIS TIME WORSE..I HAD THE CAR RUNNING FOR AROUND ONE HOUR AS IT WAS COLD YESTERDAY..AS IT WAS FITTED ..IM TOTALLY LOST NOW...I HAVENT BEEN OUT TO IT AS I JUST GOT !Removed! OFF WITH IT LAST NIGHT..& PARKED IT UP..BUT..A GOOD MATE TOOK OFF THE THROTTLE & MANUALLY ADJUSTED THE TICKOVER TO 1,300 REVS TO GET ME HOME AT 7 PM..HE SEEMS TO THINK ITS A ISSUE WITH THE MAF SENSOR..EVEN THOUGH IT WAS REPLACED..AS ITS REALLY BASIC TECH..IM DROPPING IT OFF AT 9 AM TODAY..HE WILL TRY TO READ THE ECU..SO I,L TAKE IT OFF& SEND IT BACK TO E BAY..IM RINGING FORD TODAY TO GET A O/E PART..IF THATS THE PROBLEM..IVE NEVER HAD THIS MUCH GRIEF WITH A USED FORD..I MAY SELL IT & BUY A NICE 2L TOTOTA CELICA..I KNOW THATS LOCAL..THIS IS IT..THE LAST STRAW..I WAS GOING TO TAKE IT FOR A WEEK OVER TO FRANCE THIS MONTH..BUT I CANT TRUST IT..SO IM TAKING MY 2011 REG NISSAN NOTE 1.6..A SHAME I KNOW BUT..I CANT TRUST THIS MOTOR...IT MAY BE A CHEAP FIX..BUT IM SHOVING IT ON GUMTREE TODAY...FOR £995..THE SMELL BEHIND THE CAR IS TERRIBBLE..IT SMELLS LIKE ROTTEN EGGS..& THE BLACK SOOTED EXHAUST IS BACK WITH A VENGANCE..£30 FUEL FOR UNDER 100 MILES..ANY IDEAS???? ![]()
Latest Comments
More
