Basically i drove home from university the other day which was 140 miles straight down the m5, however when i got into my town and change down gears my car started reeving on its own accord! i thought it was just me as it was late at night and i was a little tired.. however ever since when i start driving and i change gear, i dip the clutch then change gear and as soon as i dip the clutch and say pull it down to second gear it revs dramatically on its own accord reaching 3000 revs sometimes, no matter what gear i change it to it does it. Its reaches up to 4000 when i go to first then stop and go to neutral or even when i go straight to neutral it goes mental and doesn't stop revving until i either brake and wait for abit or go change gear and pull off...Does anyone have any idea what it could be?...Iv checked the obvious things like clutch, accelerator linkage or getting stuck, air filters and anything else mechanical it could be, does anyone know of any electrical problems that could cause this??
Ford Fiesta Zetec 1.25 Revving Problem???
Started by TinaP354, Feb 10 2013 09:45 PM
3 replies to this topic
#1
Posted 10 February 2013 - 09:45 PM
#2
Posted 10 February 2013 - 11:12 PM
http://www.honestjoh...dex.htm?t=36472
might be of use to you
Theres a few things that could be causing the problem
Also read somewhere that it could be a rip or hole in the air intake hose
#3
Posted 10 February 2013 - 11:33 PM
Thank you, I'll have a look at the air intake hose tomorrow and see what I can find! X
#4
Posted 11 February 2013 - 10:10 PM
You would probably have a higher idle if there was a drastic hole in the intake, you could check the Idle Air Controller, that will be a laptop job, otherwise it could be emissions related, out of interest how did you check the clutch its self?
