AdBlock Warning
John-231
Help Me Locate The Fuel Injectors On My Fiesta Mk7 1.25? - I Think They Need Cleaning.
5 posts in this topic
Hi guys where do I find my fuel injectors on my mk7 fiesta 1.25 edge?
Follow the small pipes leading to the cylinder heads.
There should be some plastic things sticking into the head, with the loom clipped into each injector, there should be 4 that look similar (or at least 3, the 4th can sometimes look a little different to other 3 on some vehicles). If you can post a picture if you can't find them then someone should be able to highlight which ones are your injectors.
How many miles have you covered in it? Seems odd a petrol from 2010 would need it's injectors cleaning in my view.
Get a bottle of RedX injector cleaner that should do the job rather than fiddling about with them, and like dave says it seems a pit premature for them to be clogged up, what makes you want to clean them?
I dont mean to sound disrespectful but to be honest, if your unsure where the injectors are then i would advise you dont touch them. It sounds like you dont have much experience with injectors, messing them up is going to leave you well out of pocket!
