Tyre Valves
#1
Posted 14 February 2013 - 02:50 PM
Is it possible to change the so called auto valves for normal valves.
Are the holes in the rim standard size ?
Thanks in anticipation
Mike
#2
Posted 14 February 2013 - 05:41 PM
Help please.Having problems with a 2005 ghia x 2.5 with the tyre valves leaking.
Mike
I cant see why the valves would not be a standard size.
what do you mean by auto valves? not something I've ever come across...
#3
#4
Posted 14 February 2013 - 05:48 PM
i take it there the metal type not rubber 1s.as a rule they shouldnt be as hole is slight dff fitment
if its the same type as fitted to the mondeo ST wheels then replacing them with rubber ones causes no problems, its actually quite common as the metal ones cause the wheels to corrode
#5
Posted 14 February 2013 - 08:06 PM
Are the holes in the rim standard size ? Sorry should have said they are the metal valves with the exterior nut.
Mike
