Mk1 Electrical Problem
#1
Posted 14 February 2013 - 08:50 PM
I have temporally removed the plug from the boot release motor to prevent this from happening.
Does anyone have any ideas what the problem could be as i cant seen anything in any of the fuse/relay boxes relating to the boot release which could be a cause.
Thanks in advance
#2
Posted 14 February 2013 - 11:27 PM
It's a common fault where the wiring insulation gets hard and brittle.
Constant flexing when opening the boot causes the wires to snap inside the insulation, add condensation/rain and you get a short.
You'll want to fix it pretty sharpish or the boot lock solenoid will burn out.
I had this on my old Mk1 and patched the wires with some crimp connectors and a length of spare wire.
You may find that the damaged wire is discoloured black, cut back to a clean copper area.
Check them all as if one has gone them it's likely the others are going/gone too.
#3
Posted 15 February 2013 - 08:36 PM
thanks for the quick reply, hope it solves my problem
#4
Posted 15 February 2013 - 09:51 PM
It may be a good idea to let an Auto Electrician have a look, they'll check and replace any damaged wires and shouldn't take more that an hour.
Other symptoms to look out for are intermittent rear wiper not returning to the correct park position, third brake light not functioning and the rear demister not working properly.
I had and needed to cure all these symptoms on my previous car so have intimate knowledge of the problems.
#5
Posted 19 March 2013 - 04:59 PM
Finally someone with the same issue!! I have had exactly the same problem and its driving me crazy, as soon as i turn my key in the ignition my boot unlocks itself and it wont close unless i take my key out. Its almost like it locks it in an open position.
Ive tried changing the whole lock, checked the fuses including the ignition fuse and they are all fine, ive tried reseting my central locking system but nothing worked! However ive checked my wires and like you say they are damaged, so ill have a look into changing them.
Thanks for posting this !
#6
Posted 19 March 2013 - 05:59 PM
I had it myself so can recognise the symptoms instantly.
Took me two replacement wiper motors to figure it out so if I can save others the un-necessary expense of bits that don't need replacing them I'm happy.
#7
Posted 21 March 2013 - 04:09 PM
Right i managed to change the wire for my boot lock, i got it off a 54 plate focus in a scrap yard, i connected the wires using crimps however the boot still opens when i turn the key in the ignition and wont close again as long as the ignition is still on. I dont know what else it could be !
Although when i open my boot i can hear the lock making an unusual noise, like its trying to lock its self, could it be the lock again ?
Please help its driving me insane ! Hate having a button in the front of my car that doesnt do anything now lol!
#8
Posted 21 March 2013 - 05:23 PM
Did you patch the wires in the conduit or just inside the hatch itself?
If there is a break right up inside the rubber tube it can be hard to see.
If you repaired all the wires and it's still misbehaving then a replacement lock may well be in order.
This is how to replace it-
http://www.fordowner...onal-lock-unit/
#9
Posted 21 March 2013 - 07:07 PM
Im not to sure, i removed the black tape from around the 3 wires and i traced them as far back until the point i could see no damage because the wire closest to the lock had tears in the insulation and from there i connected the newer wire and still i had no luck.
However i think you may be right with the lock, when i first changed the lock i didnt realise how easy the key cylinder could be removed (as shown in your pdf), because i took the whole lock apart and basically went the long way around and i may have broken it in the process, ill get another lock and let you know my progress lol
Thanks again for the help!
#10
Posted 21 March 2013 - 09:25 PM
We will get to the bottom of the problem even if it kills us ![]()
#11
Posted 17 May 2013 - 12:06 PM
Right finally!!! I have acutally managed to fix the problem after going throw 3 boot locks, replacing the wires twice and buying new fuses! All to find that the problem was in my hand, my cars fob was tripping the lock and whenever it was in the ignition it would open my boot.
I noticed at first that when i was driving my doors had a tendency to lock themselves so i took apart my key fob, cleaned it with some contact cleaner and that did it!! Everything works perfectly!
After all that!! Thought i would post this to help anyone else !
Latest Comments
More
