Frankie_A_ Posted February 15, 2013 Share Posted February 15, 2013 Just brought myself a 1998 fiesta 1.4 and found it has quite a loud knocking, particularly noticeable when I go over a bump in the road. Any ideas? I've checked wheel bearings and they seem fine. The knocking is almost certainly coming from the front of the car. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
Frankie_A_ Posted February 16, 2013 Author Share Posted February 16, 2013 No ideas yet? I jacked it up and removed the front wheels today to see if there was anything obviously loose and there isn't which is vaguely reassuring. I'll take it to the garage next week and see if they have any ideas, hopefully something I can fix myself. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted February 16, 2013 Share Posted February 16, 2013 Try the anti-roll bar bushes. Quote Link to comment Share on other sites More sharing options...
Mick78 Posted February 16, 2013 Share Posted February 16, 2013 Drop links? Quote Link to comment Share on other sites More sharing options...
Frankie_A_ Posted February 17, 2013 Author Share Posted February 17, 2013 Nice one, I'll check the anti roll bar bushes for any deterioration or excessive wear. How do I go about checking the drop links? Just check for any play? Thanks! Quote Link to comment Share on other sites More sharing options...
DieselPig Posted February 17, 2013 Share Posted February 17, 2013 Unbolt them and check for smooth movement in the ball joint. They may be seized so lots of WD40, heat and swearing :) Quote Link to comment Share on other sites More sharing options...
Frankie_A_ Posted February 17, 2013 Author Share Posted February 17, 2013 Ah right, I'll have a look at those, see if I can free them up a bit:) Quote Link to comment Share on other sites More sharing options...
Gonky Posted July 22, 2013 Share Posted July 22, 2013 Youn can find out if its the ball joint or barings by holding the wheel wile it is off the ground at the sides and give it a shake (pull one side, push other at same time back and forth quickly so give it a rattle sort of thing) and check wheel bearings by doing the same but doing it from the top and bottom of the wheel to check for play/noise. I think it is that way around if not vias versa. I know one person who had this simular problem when i first started learning mechanics but it done it under braking also so he took it to the garage just to find out the wheel nuts wasn't tightend properly so it was slightly loose and rattled. If taking your wheels off try and get the torqued up to correct tightness. Mine are 90nm on my 1.3 fiesta 1996 with steel wheels. alloys will be different, yours may be a little higher or the same. Any garage should know this with using auto data A lot of people use WD40 but I tend to use GT-85 myself as that is what we used when learning mechanics in college. Great for cleanig and giving dash and trims etc a nice shine if left on to dry :) Let us know when you figure it out as I would like to know :) Good luck Quote Link to comment Share on other sites More sharing options...
Gonky Posted July 22, 2013 Share Posted July 22, 2013 Does it make noise when doing a bounce test? That is when you pust down on the corners of the car. It is usually a quick test to check dampers but it can reveal other squeaks/knocks also Quote Link to comment Share on other sites More sharing options...
