alright people just a quick questions my car is showing fault codes p120f and p0002 which relate to fuel pressure but if i look at the fuel lines after the fuel filter and before the fuel pump there are air bubbles in there is this normal ? if not is their any think common that causes it ?
the car is a 2.0 ltr diesel 59 reg zetec s
cheers if you can help
Air In The Fuel Lines
Started by Les zetec s, Feb 17 2013 02:42 PM
4 replies to this topic
#1
Posted 17 February 2013 - 02:42 PM
#2
Posted 17 February 2013 - 02:53 PM
Air bubbles usually mean the fuel filter is either not seated correctly, the filter seal is leaking or you have damaged fuel lines.
The codes point to the fuel pump though so could be a seal or line damaged there.
#3
Posted 17 February 2013 - 03:00 PM
so the air bubbles shouldnt be there?
and if the air bubbles are before the pump is that causing it to throw the codes up?
any ideas on the best way to find the leak ?
cheers
cheers
#4
Posted 17 February 2013 - 05:01 PM
Two other people recently on here have had probs after changing the fuel filter when you took the fuel lines off the top of the filter where were the o rings in the connector on the fuel line or sat on top of the filter housing if sat on top of the filter housing you will need to reseat them wthin the connector.see picture the o ring sits below the yellow piece if left on top of filter housing then fuel line is reconnected it does not seal correctly allowing air into the system .
#5
Posted 17 February 2013 - 09:32 PM
cheers neil ford changed mine last but i'll have a look
would this cause low fuel pressure warning codes?
cheers agian
cheers agian
