Which Software Obd.
14 replies to this topic
#1 Cornish Chris
Cornish Chris
    Newbie
  • Pip
  • 2 posts
  • Name: Christopher
  • Ford Model: S-Max
Posted 17 February 2013 - 08:00 PM
Hi all,
New to the forum so hello to all.
Just getting an S-Max and was wondering what OBD software everybody uses on them? Had mainly Audi/VW's in the past so used to using VCDS/Vagcom.
Any help you can offer would be great.
Cheers,
Chris
#2 137699
137699
  • 218 posts
  • Ford Model: 2006 S-max Titanium X Sport 2.5T
Posted 18 February 2013 - 06:25 PM
Any generic ODB software is of limited value. For propper diagnostics you need the full Ford IDS system - costs about £10k.
#3 FOCA
FOCA
    Feet On The Table
  • 844 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 19 February 2013 - 04:37 AM
For those not wanting to spend £10k to read their codes - you can buy an F- super online for about £22, you need a laptop with this
Alternatively a Bluefin (for Ford) handset works well, (and works "stand alone" - no laptop required) these can be picked up secondhand for a reasonable price
There is an android app, called torque, its quite a good system, you need an android smart phone and an OBD11 - bluetooth adaptor (the adaptor needs to have the ford proticols) it does real-time logging, and other things
#4 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 19 February 2013 - 03:07 PM
I have the Torque app and a generic bluetooth adapter, works a treat :)
#5 gregers
gregers
  • 194 posts
  • Name: greg
  • Ford Model: smax titainium
Posted 19 February 2013 - 07:50 PM
intresting thanks for that guys,dont suppose you have a link for the bluetooth jobby do you??
i suppose this will also work on the mk3 galaxy aswell?
#6 Cornish Chris
Cornish Chris
    Newbie
  • Pip
  • 2 posts
  • Name: Christopher
  • Ford Model: S-Max
Posted 20 February 2013 - 02:23 PM
Thanks all!
Great info. I had a quick look at the F-Super 2 and that doesn't list the S-Max. Can anyone confirm that it does work and also if it resets airbag/abs and other fault codes etc.
I've heard good things about the Torque app before. Is this used for real time monitoring or can it be used to reset faults in different modules?
Once again thanks for the responses.
Cheers,
Chris
#7 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Year: 2005
Posted 20 February 2013 - 03:46 PM
Just look on google for "bluetooth OBDII" its a generic unit, and although not bespoke to any car in particular, they read a lot from all rather than all from one (if that makes sense :P)
#8 FOCA
FOCA
    Feet On The Table
  • 844 posts
  • Name: FOCA
  • Year: Non
Posted 20 February 2013 - 05:35 PM
Thanks all!
Cheers,
Chris
Your car may have a PSA engine rather than a Ford engine, also there is several different OBD11 protocols and if you just buy a "generic" scanner it may not read your Ford fault codes, i use a bluefin handset and it deletes/ resets engine fault codes globally (all at once)
The correct (cheap domestic) scanner will read 99.9% of codes and do most of what a pro scanner can do exept things like recoding injectors etc
more info -
All petrol engined cars after 2001 and diesels after 2004 must have an OBD11 port
Where is the Diagnostics socket located? It must be located within three feet of the driver's seat and must not require any tools to be revealed. Most are located under the steering column. If your OBD II port is not there, look under the dash and behind ashtrays, on some Fords it slides dowm below the dash.
OBD II Protocols:Auto manufacturers had some flexibility in the communications protocol they can use to transmit parameters or PIDs, which are required by law to be uniform, to scanners.
There are currently five different OBD II communications protocols in use: KWP, PWM, VPW, ISO 9141, and CAN.
Most Fords use SAE J1850 PWM (Pulse Width Modulation) communication patterns,
J1850 PWM - (Ford engined cars) The connector should have locations 2, 4, 5, 10, and 16 populated
J1850 VPW - ( Vaxuhall GM etc) The connector should have locations 2, 4, 5, and 16 populated, but not 10 populated.
ISO 9141-2 - (Japan imports etc) The connector should have locations 4, 5, 7, 15, and 16 populated.
CAN Bus - The connector should have locations 4, 5, 6, 14, and 16 populated.
ISO 14230 KWP - The connector should have locations 4, 5, 7, 15, 16 populated.
#9 gregers
gregers
  • 194 posts
  • Name: greg
Posted 20 February 2013 - 07:47 PM
many thanx for the info chaps.
#10 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Year: 2005
Posted 21 February 2013 - 06:13 AM
no worries, I tended to search for "OBDII Bluetooth Focus" or "OBDII Bluetooth CMAX" etc to find it. If the product is sold to you and is incompatible, you can return it as not fit for purpose, not as described and your not out of pocket!
#11 Richiemac
Richiemac
  • 174 posts
  • Name: Richard
  • Ford Model: Focus 08 1.8 tdci + S max 2007
Posted 12 March 2013 - 11:16 PM
Buy an Elm 327 on ebay for a tenner.  Modify it as per links below. Then use ELMCONFIG, free, to read and clear DTCs and make changes  to module configurations. Used it so far to activate auto lights, wipers, cruise control and BT / Voice control......
Will start a thread about it soon on here but look on  the Focus forum links to get an idea about it........Richie.
Thread:
http://www.fordowner...nd-ff2-program/
Software:
http://civil.iffc.ru...g/ELMConfig.zip
#12 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Year: 2005
Posted 13 March 2013 - 11:26 AM
Might have beaten you to it Richie ;)
http://www.fordowner...or-on-your-car/
#13 Richiemac
Richiemac
  • 174 posts
  • Name: Richard
Posted 15 March 2013 - 01:15 PM
Here's another. Developed by the guy who aids the author of the free one above....thinking of buying it myself.
http://www.ucdsys.ru/?lang=en
Has English available and costs about   £ 80 delivered.
#14 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Year: 2005
Posted 15 March 2013 - 02:07 PM
£80 is a bit steep, spesh if you can get a free and equally good equivelant... I wonder if we could all put in and buy shares in it :P
#15 Richiemac
Richiemac
  • 174 posts
  • Name: Richard
Posted 15 March 2013 - 02:17 PM
It does more than Config obviously, but can't help wondering if in time  Config will catch up anyway.
