Usb Connectivity With Iphone 5
18 replies to this topic
#1 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
  • Ford Model: Focus Titanium 1.8 TDCi
Posted 17 February 2013 - 10:05 PM
I know that I can buy a USB/3.5mm to 30 pin connector but my new phone uses Apples terribly annoying new 'lightning' adaptor.
Does anyone know of a USB/3.5mm to Lightning adaptor for my car?
I think it will still work with the HU because the tracks display on the screen, just missing the audio :-/
#2 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,466 posts
  • Name: Clive
  • Year: 2007
Posted 18 February 2013 - 01:18 AM
If you do a firmware update for your radio you can just use a USB to Lightning cable without the need for a 3.5 connection.
I'm sure someone here will point you in the direction of the update.
#3 vibeone
vibeone
  • 82 posts
  • Name: Mark
  • Ford Model: Focus MK2.5 2.0 TDCI
  • Year: 2009
Posted 18 February 2013 - 03:00 PM
Am I missing something?
I have a focus with bluetooth/USB in centre console and plug my lightning cable straight in... works fine?
#4 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 03:19 PM
Wish that worked for me! Have you got the silver SONY unit?
#5 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 03:20 PM
Oh and a firmware update?? Wouldn't know where to start :-/
#6 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,466 posts
  • Name: Clive
  • Year: 2007
Posted 18 February 2013 - 03:37 PM
There's quite a few members here that have applied the update, it installs from a memory stick and takes about 20 minutes I believe.
If you search for radio update you should get all the info you need.
#7 vibeone
vibeone
  • 82 posts
  • Name: Mark
  • Year: 2009
Posted 18 February 2013 - 04:00 PM
I tried the update for the sake of it, and it errored. I'm guessing it was already up to date.
Still a bit confused though, if you have a USB port, what happens when you plug an iphone 5 into it with a apple lightning connector?
I have the sony DAB unit
#8 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 05:05 PM
I have the same unit. When I connect it with the original lead I am able to control the iPhone and see the track on the screen but there is no audio!
#9 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 05:14 PM
This happens with lightning cable for iPhone 5 and the 30 pin connector for iPod Touch. I'm guessing the unit is screwed...deep joy!
#10 Preee
Preee
  • 3,063 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3
Posted 18 February 2013 - 05:22 PM
Go here and follow instructions it's very easy to do , and might solve your problem , chances are your audio has never been updated
http://www.ford-mobi...ownloadsUpdates
#11 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 05:26 PM
Thank you, I will give this a try and let you know
#12 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,466 posts
  • Name: Clive
  • Year: 2007
Posted 18 February 2013 - 05:27 PM
Before the update with the older iPhone 30 pin connector you need the ford cable with the connector and a 3.5 jack plug, afterwards you only need the 30 pin connector so it should be the same for the lightning cable.
Before the update you needed this-
http://pages.ebay.co...id=170896821925
Afterwards you just needed the cable which came with your phone, in your case the new lightning one.
If you can't do the update then buy the cable as linked above and one of these-
http://pages.ebay.co...id=111007729271
That should solve the sound problem.
#13 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,466 posts
  • Name: Clive
  • Year: 2007
Posted 18 February 2013 - 05:35 PM
http://www.fordowner...__fromsearch__1
#14 S4M3G
S4M3G
    Member
  • PipPip
  • 10 posts
  • Name: Sam
Posted 18 February 2013 - 07:13 PM
Well...update failed -_-
#15 Preee
Preee
  • 3,063 posts
  • Name: Paul
Posted 18 February 2013 - 07:17 PM
Things you need to check , are the memory stick was clear before you added the files , and when following instructions for update you don't touch anything at all. , I have only ever had it fail once , and i have dont it many times
