55 Focus 1.6 Tdci Egr Blanking Success
I thought I'd just post my recent experiences regarding the pesky EGR valve on my 55 1.6 tdci focus. Had to act following numerous and increasing limp mode activations and associated red cog illuminations. Spent a few evenings on this forum which convinced me that blanking it off was the way to go. (thanks to all the expert contributions)
First tried unplugging the EGR valve with very positive results although it brought the engine MIL light on after the 3rd start. Bought a stainless steel plate off flea bay for the price of a pint and fitted it on Saturday.
I only removed the engine cover bracket and pushed the fuel filter out the way 6 bolts in total. Found no need to remove the plastic scuttle or wipers. Used the wife's small mirror to see the 2 bolts on the EGR and slacken them off. Slid the plate manifold side of the gasket and tightened it all up etc. Including re-attaching the plug and restting the MIL it only took about 30 minutes.
Happy to report 250 miles with no limp mode and no engine lights on. If you're in any doubt, give it a go. It's not challenging and the benefits are immediate.
All the best
I did exactly the same on Sunday with mine and have to agree with your comments..... Easy to do and instant results :)
Is there any sort of performance benefits to the blanking in your experience?
probably no performance benefits but its the crap from building up and throwing engine lights
Agree with sal and lotty.Glad I did mine now and its not as hard as I thought to fit.Just got to clean out the inlet manifold now to really benefit from the cleaner air in the engine but its a bit trickier to do...No lights on on mine yet too... :D
All the best
Hi - what benifits did you notice?
Theoretically there are performance benifits because the burnt exhaust gases that are normally injected into the engine are replaced by (relatively) cool clean air,
The EGR valve/ system may operate at specific revs/ conditions (eg at certain low revs/ at part throttle) so the EGR valve may be designed to close at higher revs or full throttle
So the difference fitting a solid plate may be quite subtle and may be percieved as "smoother running" or "less flat spots" and not "better performance" but nevertheless, the engine should pull/ pick up better within from low revs (in the "EGR zone") - so a slight performance improvement is normal
To get the full benifit, the inlet manifold/ EGR valve needs to be cleaned out completely, and the ECU reset. this may give a more noticable improvement
If 2 solid plates are used, (one near the inlet/ EGR and one close to the exhaust manifold/ EGR cooler) and the EGR pipe is removed, this can have further performance (and efficiency/economy) benifits, because the inlet stays cooler (cooler = denser charge = more oxegen per cc = more power) and the volume between the engines exhaust outlet to turbine is reduced/ less exhaust energy is lost, reducing lag, increasing throttle response/ power
Again, this is not a massive gain, but adds up in conjunction with other modifications, like remaps, bigger intercoolers etc, and economy is liable to be a little bit better. And reliability (the EGR cannot go wrong if its not there!)
My obd scanner says that the egr flow is normal...How can that be seeing as its blanked??? :unsure: Interesting...Also the flat spot I was having is just my right foot,I only slightly depress the pedal normaly but today I booted(put my foot down) and boy did it fly(well for an estate it wasn't too bad)lol...and no flat spots... :)
  • 1 year later...
Hi I have a 2004 c max which has been plugged into the computer and comes up with egr fault. Also I have a battery drain as the engine managements staying on because of a fault. I was wondering if I put the blacking plate on will this sort this. Thank you
I blanked the egr valve about 8 months ago. Less smoke, beter pick up, no lights in the dash. but I also found I'm getting less mpg. was having around the 50 mpg mark but it dropped to anything from 40 to 45.so took the plate of. Now it's back up to the 50 again.
Is this normal??.
Is this normal??.
Interseting as i did mine over weekend and have noticed this also, im not booting it or anything but its still going down.
Is this normal??.
Exact same thing with me mate.
Was getting 49 MPG around 4 months ago, blanked EGR and MPG has dropped significantly to 42 MPG.
Thinking of taking the blank out to be honest.
I found my MPG improved (as well as the performance) with the EGR blanked, the trip computer / displayed MPG may not be accurate/ may not be reading the true MPG and perhaps fitting a blanking plate changes the displayed MPG
Theoretically the MPG should improve with the plate fitted (cleaning out the inlet manifold and resetting the ECU (as well as the trip computer) may help/ get the most out of the plate)
Ok thanks foca,will give it a try.
  • 1 year later...
My Son's 05 TDi 1.6 Focus engine just stopped the other day, towed it to a mate's garage and he put the OBDII reader on it and says its the EGR valve - he also said the solenoid coil is open.
I've ordered a blanking plate, but just wondering if I'll have to fool the system into thinking the coil on the solenoid is still working. In that case anyone care to measure the resistance of it so I can put in a resistor to simulate it?
Also his is a valeo model (the most expensive one! ) can other makes be substitited or are they phsically different (they look the same on the parts web sites out could be a generic picture)
Andy
it won't clear the error messages but it would change the performance.
  • 5 years later...
Hi I am not sure if posting here on this old thread is the best way. So please let me know.
I have just blanked my focus 1.6 tdci today. Mainly after reading up on the benefits. I can report that all turbo lag is now gone on the 2nd and 3rd gears. Well impressed.
However, I squirted some soapy water on both connections of the Egr valve, to see if they were any exhaust leaks. The connection around where the plate was inserted did have a small leak. I cant smell any exhaust in the cab.
Is this something I should be concerned about now the valve is blocked?
