White Smoke From Exhaust - 1.6Tdci (110) Feb 2008
Smoke Focus TDCi Exhaust
10 replies to this topic
#1 Howard1471
Howard1471
    Newbie
  • Pip
  • 6 posts
  • Name: Howard
  • Ford Model: Focus 1.6TDCi Zetec Feb 2008
Posted 21 February 2013 - 07:36 PM
I've owned my 1.6TDCi for 2 years. 18 months ago the DPF was removed, and Engine reconfigured, after if failed and the garage ( and the AA man ) was unable to reset it. The car had approx 65K on the clock at that time. Over the last 12 months I've noticed white smoke coming from the exhaust. This does not happen all the time.
When I travel at motorway/Dual Carraigeway speeds the car runs fine but as soon as I ease up for the slip road white smoke comes from the exhaust. I can drive to-and-from work ( round the ring road ) and all will seem ok. Then, as I turn into the offce, I notice it again. The only constant condition is that it occurs when I ease off, if I open the throttle even slightly the smoke disappears.
Has anyone any [sensible] suggestions?
Things I could check myself. I'm not adverse to getting the bonnet up.
#2 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,460 posts
  • Name: Clive
  • Year: 2007
Posted 21 February 2013 - 09:32 PM
White smoke norrmally means that the fuel injected into the cylinder is not burning correctly. The smoke will burn your eyes.
Engine/pump timing out
Fuel starvation to the pump causing the pumps timing not to operate correctly
Low engine compression
Water/petrol in the fuel
It could well be the cam position sensor.
#3 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 21 February 2013 - 09:40 PM
or worn injectors
#4 Howard1471
Howard1471
    Newbie
  • Pip
  • 6 posts
  • Name: Howard
Posted 23 February 2013 - 08:30 AM
OK, that would fit with something the garage said when they serviced the car a few weeks ago, some sealant on/around one of the injectors. Could a leak in that area cause this problem ?
#5 RAF258
RAF258
    Newbie
  • Pip
  • 1 posts
  • Name: Richard
  • Ford Model: Focus
Posted 10 April 2013 - 10:05 PM
Howard, did you manage to get this sorted?
I have exactly the same problem and the car has just failed the MOT emission test. It's done 97K miles.
#6 Howard1471
Howard1471
    Newbie
  • Pip
  • 6 posts
  • Name: Howard
Posted 11 April 2013 - 09:07 PM
RAF258
Yes It's sorted, cost a few "bob" but it's sorted. :)  Read on.
I removed the engine cover to inspect the "sealant" I had been advised about.  The rightmost injector was puffing out exhaust like an old Mamod Steam engine. Obviously got a leaky injector seal. Consequently the black "sealant" turned out to be Carbon deposits from that leak. Reduced compression, poor ecomony etc etc. So much for the garage that did the service, how could they miss this lot?  I spent a couple of days patiently removing the Carbon, there was a lot.
I wanted to replace the seal but couldn't budge the injector. Got on to Yell.com and found a local mobile mechanic, he came and looked at it with his diagnostics computer and advised me that the injectors were all buggered and would need replacing before they failed completely ( Cheaper to service swap than replace ). It took him about 30 mins to remove the leaky injector, fit a new seal and put it back together. Re-primed and started.  He advised me that the Manifold would be full of S##t as would the EGR valve. This I'd read about. Not good for Turbo life. When he came back with the replacement injectors he cleaned out the aforementioned, fitted the new bits and it's now back on the road with no white smoke.
The lesson to be learned here is that despite how simple these things look in the Haynes Manual, it's far easier to get this sort of thing done by someone with the kit and the experience. Well worth paying for.
If the Injectors are down, replace them whilst you can swap for recon units. If they go altogether the cost is doubled.
#7 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 12 April 2013 - 12:44 PM
what was the total cost in the end?
#8 Howard1471
Howard1471
    Newbie
  • Pip
  • 6 posts
  • Name: Howard
Posted 14 April 2013 - 10:34 AM
1. The original call out, remove injector, clean, fit new seal, reinstall, fuel prime, clear diagnostics codes and start, £50.00
2. Purchase reconditioned Injectors ( Unit Swap ) , 4 off @ £150.00  = £600.00
3. Replace all injectors, remove and clean exhaust manifold and EGR valve, reset ECU codes to Factory defaults ( someone in the past had tinkered ), reprime, start and test drive. £150.00
Total paid £800.00.
I've found a local Mechanic with a lot of diesel experience, with cars and commercial vehicles ( Vans etc ).  The costs are kep down by paying cash and not looking too closely at the figures on the invoices. ;)  Suits me.
#9 jeebowhite
jeebowhite
  • 4,310 posts
  • Name: James
  • Year: 2005
Posted 15 April 2013 - 12:05 PM
Ouch!
#10 Howard1471
Howard1471
    Newbie
  • Pip
  • 6 posts
  • Name: Howard
Posted 16 April 2013 - 11:19 PM
The problem, as I understand it, with this engine, is that it churns out a lot of muck. The EGR valve recirculates exhaust gases, complete with all the soot left over from the combustion. This builds up a residue in the manifold and EGR valve itself and gets in the oil. The sooty-oil clogs up the Turbo oil feed and pickup pipe which in turn starves the turbo of lubricant and when that fails, as a result, the whole thing gets well expensive. This is all compounded when the EGR valve, itself, gets stuck because its cloogged up and stuck open.
I'm advised that low soot/ash oils are a must and a regular oil change is very beneficial. My advice to anyone is get the Manifold and EGR valve cleaned out if it's never been done. Do an oil change every 3 months ( depending on use ) and check for injector leaks ( Hold your hand over each injector to see if there's exhaust puffing out ).
And most importantly, get someone who knows what they're doing, to do it all. :)
#11 FOCA
FOCA
    Feet On The Table
  • 846 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 17 April 2013 - 02:51 PM
^^Or the problem could be circumvented by fitting a solid EGR blanking plate, thus stopping the carbon/ muck getting into the inlet (manifold) in the 1st place, you wouls have to clean the EGR/ manifold every day ant it would still not be as effective (as a solid EGR blanking plate) + once the plate is fitted, the inlet manifold/ EGR housing only ever has to be cleaned once
 You have inadvertently made a compelling argument for fitting a solid EGR blanking plate
I agree that frequent oil changes are benificial, but every 3 months is a bit >>too<< frequent, even if you are doing 12k a year thats every 3k miles and 4 oil changes in a year, quality oil is expensive (Castrol Magnatec can cost £30 for 4 litres, one can isnt enough- so you buy 2 = 60, not counting the cost of the oli filters, or paying someone to do it, 4 times a year?)
Some people work long or unsociable hours, or live in remote areas, and may find changing oil every 3 months/ 4 times a year inconvenient
On the Mondeo diesel, the original oil change interval was 5k, then it was 6 ("semi synthetic" oil) then it was 10k, then finally 12k ("fully synthetic" oil) i think some of these intervals are a bit long, in my opinion, and changing the oil more frequently will help to clean out the contaminents (with the oil change) as you have suggested, but 5k/ every 6 months is probably frequently enough for an oil change, in my opinion, especially with a solid EGR blanking plate fitted.
