Changing Brake Pads
3 replies to this topic
#1 charlie866
charlie866
  • 51 posts
  • Ford Model: fiesta 1.4 titanium 5dr in Avalon Blue
Posted 22 February 2013 - 09:49 PM
Going to replace my brake pads on my 1.4 2009 titanium. Do they still recquire the 7mm allen key or have the screws been replaced by bolts. Only asking because my replacement pads come with 4 bolts. Thanks. http://www.ebay.co.u...984.m1438.l2649
#2 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 22 February 2013 - 10:02 PM
no they are different, they use sliding pins (not acutally sure what they are called). although im not sure if all models have the same setup?
heres the type im on about that uses the sliding pins
http://www.ebay.co.u...=item35baa6bc14
#3 DieselPig
DieselPig
  • 206 posts
  • Ford Model: Fiesta Zetec 1.6 TDCi
  • Year: 2011
Posted 22 February 2013 - 10:27 PM
The replacement bolts hold the pins in place to the piston assembly. You have to remove them to lift away the piston assembly to reveal the pads and shims.
#4 Jammie710
Jammie710
    Member
  • 17 posts
  • Year: 2003
Posted 01 March 2013 - 09:51 PM
It's a 13mm bolt tht holds th calliper to the calliper carrier so undo the 2 13mm bolts and lift th calliper off to get to the pads
