Fiesta Mk6 Fuel
#1
Posted 23 February 2013 - 06:12 PM
I'm about to start work experience with a company in barwell, Leicestershire, which will double the amount I spend on fuel each month. However, as I know that my 57 plate 1.6 fiesta zetec s' fuel guage isn't the most accurate, im quite tempted to simply brim the tank, fill up a fuel can to carry in the boot, and drive the car until it completely runs out, finding out once and for all how many miles I can get off a full tank, then use the contents of the fuel can to get home, or to the nearest petrol station. My only queary is whether I can simply put more fuel in after it runs completely out and stops, or whether the fuel pump has to be primed or will object in any way,
Any advice much appreciated,
Peter
#2
Posted 23 February 2013 - 06:27 PM
#3
Posted 23 February 2013 - 11:55 PM
#4
Posted 24 February 2013 - 12:02 AM
#5
Posted 24 February 2013 - 12:13 AM
Filling up more often means that you won't have used as much fuel, meaning that each fill up will be cheaper. For example, if one £60 tank lasts you two weeks, filling up every week will cost you £30. Exactly the same amount spent in the long run, no matter how expensive it is. Trying to run your car on empty won't make it any cheaper to fill up.I also have a thing about buying fuel before I absolutely need it , as it isn't cheap these days!
#6
Posted 24 February 2013 - 12:23 AM
#7
Posted 24 February 2013 - 04:31 AM
You must consider you cannot control where you are when you run out of fuel, and if its the outside lane of a Motorway it would be dangerous, also, you may run out at a bad time (eg - late for work etc) bad news in a petrol and very bad news in a diesel
So it would be better for the car, safer, save time and be more convenient to not allow the car to run out of fuel
Brimming the tank :-
My ex gets paid monthly, when she gets paid she fills her petrol tank right up, and hopes it lasts till the next month
She drives a tiny little (petrol) Kia, i tried to explain that the full tank represents a significant amount of weight in the car and she would be better putting half a tank in twice a month, and get better performance/ economy (and traction in the snow
We can do the figures with a Fiesta -
Tank capacity = 43 Litres
Weight of 43 litres of petrol = Approx 30kgs (approx 3/4 the weight of water/ depends on temp)
Weight of 1/2 a tank of petrol = Approx 15kgs - does not sound much but it adds up and you will feel the difference in a small car
Diesel is a bit heavier than petrol too
Running the car near empty and just putting a little in (like a tenner) is the other extreme, I suppose waiting in line in filling stations/ supermarkets is time consuming and for some would add to the journey length/ mileage which means more topping up/ the possibility of getting "cought out" or having to top up at inconvenient times
Of course, if you are going on a long trip or if you recon the price of fuel is going up soon, (like now!) "brimming" it may be a good idea but running around with extra weight is not ideal either - and "topping it up" when it gets to halfway every time means you are just lugging about extra weight un-nessesarily
I feel its just a question of getting the balance right for your needs/ type of driving - but letting it run out - i personally would'nt
A long time ago i had a Sierra with a broken fuel gauge - i had to run with a can of petrol in the back, the seal was burst on the can and it was letting fumes into the cabin, after a long run the effects of this are similar to alchahol or solvent abuse, and (mainly) due to this i had an accident and "wrote off" tha car, luckily, no-one was hurt (this all happend because of a broken fuel gauge)
Petrol is obviously flammable too, and if you are a smoker/ have smokers in the car, it can be a recipie for disaster, especially if your mates are drunken idiots (trust me on this one)
its easy to spill a little petrol/ diesel on the can when you fill it - and it stinks too - (Almost) nothing worse than having the smell of petrol or deisel in the car all the time
nuff said
#8
Posted 24 February 2013 - 09:26 AM
#9
Posted 24 February 2013 - 05:38 PM
I think members should be encouraged to put more info on their posts and profile/ avatar, like petrol/ diesel, engins size etc etc, it would save a lot of time / hassle
#10
Posted 24 February 2013 - 05:42 PM
It just says zetec-s - zetec - a trim level,
Coming from yourself who simply has 'Ford' as your ford model
#11
Posted 24 February 2013 - 07:16 PM
^^^This!
