AdBlock Warning
vinylpusher
Wire Interior Lights To Headlights?
12 posts in this topic
Hi, Is there a guide anywhere to be able to wire some LED strips so that they only come on when i have my headlights on??
If this isnt possible. Which cables can i splice into so that i can have a center console LED permanently on??
I would rather just with headlights though
Maybe some of the interior lights behind the heater panels or dashboard? anywhere lights come on when the headlights are on
Hi Ben,
Few options for you would be;
Fit a 3 way rocker switch next to the OBD port in the drivers side footwell,
Wire it so as position I
Is on when doors are opened,
Position O
Is off in any circumstance
Position II
Is on with the interior dash illumination,
I highly recommend fitting a switch in any case because coppers don't like interior lighting,
And this way you can deactivate on approach to checkpoints etc.
Another advantage to splicing in to existing interior illumination is;
If you fit a standard ford lighting switch with dimmer wheel,
Your extra lighting can also be dimmed,
You may like to view my guide in the list below this post for rear footwell lighting,
I will now check the haynes manual and inform you of the wires to splice in to for interior illumination,
Hi Ben,
Position O
Position II
Hello.
Thanks for the suggestions.
Looking around for suggestions i would much prefer it to be on the interior dash lighting so that i could use the dimmer for it aswell, as sometimes may not want it so bright.
That would be really helpful if you could find that out for me as ive searched google with no answers :( lol.
Would it be a case of just splicing into that? or would i need to add a switch?
Ive never hardwired any LED strips as my Footwells lights were already in place luckily and all other LEDS in previous cars i have just used the Cig lighter. But would rather not have cables running everywhere and extensions sticking out the socket
Thankyou
If you remove the panel on the centre console near the clutch pedal you'll be able to see the lighter socket wiring.
Taped to that is an unconnected wire which is for an illumination ring around the lighter socket if you ever fit a dash ashtray/cubby.
If you tap onto that line and then earth lights to a bolt or screw on a metal piece of car frame or panel you'll be fine.
I can confirm that this live feed will dim on the headlight dimmer wheel.
Hello.
Thankyou
No problem,
At the rear of the centre console switch for the rear window demist button,
Splice in to the Orange&black feed for lights on positive
And
Splice in to black for negative
Using some cable
http://www.ebay.co.uk/itm/Twin-Core-3A-amp-12V-Black-Red-DC-Power-Cable-per-5m-/170492569100?pt=UK_In_Car_Technology&hash=item27b226260c
Run a feed to a rocker switch, and fit it in the OBD port area of the dash,
Depending on what colour of leds you plan to fit, id advise purchasing an illuminating rocker switch to match,
This way, when your lights are active;
The illumination from the switch will also act as a light for the OBD pocket area,
Then run a feed from the rocker switch to your new lights.
Ok thankyou i will take a look. To remove the side panel is are there just torx screws ?
One torx screw under a pop out cover.
You can't miss it.
The dash lights up with the sidelights,(position 1) not the headlights (position 2)
Thanks for both the different options
I want just a mellow glow really. Don't want a pounding blue light.
Anyone suggest good LED trips for interior lighting ? Would the door handle ones in the guide be quite subtle?
How would you suggest mounting the switch ? Dont fancy something just dangling around. I dont really want to do anything too permanent (EG cutting the dash)
With your method mellow. Would i need a switch at all?
Either way. Just meant that i dont want them on all of the time. Only when its dark enough that i need headlights (Sidelights) on
