Engine Management Light On. Any Advice Appreciated.
#1
Posted 25 February 2013 - 12:26 PM
Just wondering if anyone could help. My EML came on a few days ago, and I would like to reset it to see if there is a problem or if it's just a reminder.
Also wondering whether there were any common reasons for the light coming on, whether there is a particularly likely problem it represents, or whether it just could be anything!
I own an '03 plate Mark V Fiesta.
Thanks,
Foxhall.
#2
Posted 25 February 2013 - 01:33 PM
#3
Posted 25 February 2013 - 01:40 PM
Yeah got the RAC coming out to do it free. !Removed! good service. I want to get a Bluetooth adapter for it so I can do it myself in the future and just because I'm ever so slightly geeky. Can you tell me if ODB2, ODB11 and ODBII are different. I have seen all three variations written.
Thanks again.
Foxhall.
#4
Posted 25 February 2013 - 02:09 PM
#5
Posted 25 February 2013 - 02:16 PM
#6
Posted 25 February 2013 - 06:50 PM
Foxhall.
#7
Posted 25 February 2013 - 07:06 PM
So the light is back on. The fault code was to do with the Heating Control. The RAC guy said that the lambda sensor had been on the blink. How much is this going to cost me do you think?
Foxhall.
Dont go with a cheap universal sensor, you will soon be replacing it again
for an ngk or denso sensor you will probably be around £100
#8
Posted 25 February 2013 - 07:14 PM
Foxhall.
#9
Posted 25 February 2013 - 07:24 PM
The pre cat sensor will have a heating element to get it up to temp quicker so it may have failed.
do you know what the fault code(s) are?
#10
Posted 25 February 2013 - 08:02 PM
Is NGK and NTK the same make, and perhaps more importantly, is my Fiesta a Mk5 or Mk6, parts website have told me that it's both!?
Thanks again,
Foxhall.
#11
Posted 25 February 2013 - 08:09 PM
I can't say for certain. I got a glimpse of it but the RAC chap just said that it was sorted and that it might play up again. I thought that was the end of it for the time being. I have however ordered a code reader from amazon, a bluetooth one that will send lots of fun data to my phone. I will let you know when I have it. Else is there a list of the fault codes, I could find ones that relate to tthe lambda sensor and heating control and see if I recognise them.
Thanks again,
Foxhall.
yours is a mk6.
yes they are the same company
#12
Posted 28 February 2013 - 07:52 PM
Back again. Got my Scanner today ran some diagnostics, first thing I did was check fault codes, here is the result:
Thank you for all your help. It's been really useful.
Foxhall.
#13
Posted 28 February 2013 - 08:19 PM
pre cat oxygen sensor as suspected
#14
Posted 28 February 2013 - 08:23 PM
Yeah. I'll look at buying a new one. I read that it could be a faulty connection or just broken all together. Caused by age and collisions, which it has had quite enough of! I'll just kill 2 birds and replace it. Are there any suppliers you would recommend?
Thanks again for all your help, such a great community.
Foxhall.
#15
Posted 28 February 2013 - 08:39 PM
Foxhall.
it could be a bad connection, you might want to unplug it clean it then reconnect it but i suspect its a faulty sensor.
You could try euro car parts, they do the big names and you might also be able to get 25% off too
Latest Comments
More
