Rossitron Posted February 27, 2013 Share Posted February 27, 2013 Hi everyone I've had the car since September and it has the glow plug problem, if you over gear or try and progress too much in 5th / 6th the flashing glow plug light comes on and it goes into limp mode. I have had a few bottles of Wynn's in the tank and this has improved some, but if you rev too hard, it still black smokes a little. Since Christmas I've had trouble starting it in the mornings with the cold weather. At first I could jump start it from another car, but this stopped working and it had to be bumped off. As soon as it is going, it is fine for the rest of the day, until it is left overnight! It is a bit rough when idling, but I changed the fuel filter on Monday and this seems to have improved. On Tuesday morning I was able to start it (with a bit of effort), but again today it was back to being bumped off. I had the battery tested and the guy stuck a code reader on, which threw up the P0251 fault, someone else suggested it could be the injectors. I haven't tried any easy start, which I will try tomorrow. I was wondering if anyone had any other suggestions before replacing the injection pump fuel metering control? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
mintalkin Posted February 27, 2013 Share Posted February 27, 2013 the most common cause of P0251 is a knackered injector, first job would be to get a leak off test done this will confirm if the car has a bad injector or not. Quote Link to comment Share on other sites More sharing options...
Rossitron Posted March 1, 2013 Author Share Posted March 1, 2013 the most common cause of P0251 is a knackered injector, first job would be to get a leak off test done this will confirm if the car has a bad injector or not. Thanks for the reply, would a knackered injector(s) cause cold starting problems too? I used easy start yesterday morning and it started on its own this morning! I'm still getting the intermittent glow plug problem, but the last time it happened, it didn't go into limp home mode, the plug just flashed. I will do a leak off test as soon as I can get the gear. Quote Link to comment Share on other sites More sharing options...
Rossitron Posted March 5, 2013 Author Share Posted March 5, 2013 Update: Leak off test complete, looks like injectors 1,3 and 4 are knackered. How much does it cost to have them reconditioned and is it only Ford that can do it? Quote Link to comment Share on other sites More sharing options...
