New Here, Need Some Input On Retrofittings
166 replies to this topic
#1 neps
neps
  • 79 posts
  • Name: Espen
  • Ford Model: Fiesta
  • Year: 2009
Posted 27 February 2013 - 08:36 PM
Hi
New member from Norway here. We dont have a community like this here, in Norway ford=mondeo, or the rest is old sierra/cosworths.
I just got my 2009 1.6 tdci ECOnetic. The last 5-6 years Ive been driving mostly VW Passats, but my current 1998 Passat have given me so much grief the last months, that I had to get a newer car, more reliable with less problems (hopefully!!), and better mpg for my daily 100km commute.
I know that its general better to spend more initially and get a car with oem fitted equipment, unfortunately that did not fit my budget this time. So I have the following wishes:
1.Replace the "6 button" radio with something that got usb/bluetooth/phone support. (i know you can retrofit usb/bt, but how about the bigger head unit?) I have found a couple on ebay, but they dont come with the code? What do i do?
2. I have the manual AC/Heater control, Can i retrofit the automatic climate controls? I guess this will need some coding aswell, and in addition to the controlpanel, i guess i will need some modules, and/or temperature sensors?
3. Heated windscreen. Possible? I can source the windscreen from a friend that works with carglass, but what do I do with wiring/relays?
4. Heated seats, I have the heated seats, but they are only on/off, And I litterally burn my !Removed! off when using them, Can this be upgraded to a 5-step one like the mondeo have?
5. Parking sensors. This should be a easy one. I have found the dolphin sensors wich seems to be the best units. Any comments on this? I saw there was a brilliant guide for the install job here on the guide section aswell.
Thanks in Advance!
#2 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 27 February 2013 - 08:53 PM
Welcome to the forum :)
1) Yes it's possible to retrofit Bluetooth & USB with the larger screen, it's a lot of work and parts required plus needs activating by someone with a Ford IDS.
2) There was an aftermarket kit around last year for 420 Euros, haven't seen it since though. In a word, no. It's not worth the hassle.
3) I know people have done it on the MK6 Fiesta, not heard of anyone doing it to the MK7 yet.
4&5) Not sure, sorry. Hopefully someone else will be along soon to answer :)
#3 neps
neps
  • 79 posts
  • Name: Espen
  • Year: 2009
Posted 27 February 2013 - 09:00 PM
Thanks Nathan
The stereo is the main concern. Ive read through most of the related posts in here. And I have allready sent the parts list to my local Ford dealer, the module was very expensive though. I have found one on ebay, but I didnt want to buy that one before I know for sure that its possible to replace the head unit aswell. Do you know the process involved in that? Is it as simple as repace the unit and have Ford re-code it with the IDS system? What about the microphone for the Bluetooth setup?
Thats interesting.
I can see that the connections behind the controls are completely different. So i guess this will not be do-able without rewiring most of my dash.
#4 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 27 February 2013 - 09:05 PM
I mainly deal in cruise control, powerfold mirrors, ambient lights, and USB activation. Only 2 customers so far came to me without Bluetooth, and added Bluetooth & USB. Both of those customers installed all the hardware themselves and only needed my help for activation so the information I'm about to give you is third hand directly from them.
I think i can remember most of them . If i remember ill try and find the invoices out with the finis codes on them.
Bluetooth module
screw to bolt module to panel
Mic
Panel for roof (needed to cut out some of roof lining, while doing that i also added a focus interior light with map lights)
Stalk with voice control button
Multiline display
Control panel with extra buttons
new plastic trim for USB port
Usb port itself
I think i had two loom extensions one which had the module/control panel/usb sockets and another which went up to the mic which plugged into the other one (not 100% certain)
For the module, make sure you get the type with a 'mini-USB' connection, any of the following part numbers are correct (higher that last letter the newer the module, all work the same though)
8M5T-19C112-AN
8M5T-19C112-AP
8M5T-19C112-AR
8M5T-19C112-AS
8M5T-19C112-AT
The extensions (mentioned in the parts list above) are reference to an old wiring loom which needed 2 cables for the USB, if you buy the newer module above you do not need to worry about them.
The entire loom (from module to stereo, and mic) looks like this:
It usually includes the USB cable as well but not in my photo as I cut it off to use for a customer. In the UK that entire loom costs around £53 brand new from Ford.
#5 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 560 posts
  • Name: Allan
  • Ford Model: Fiesta 1.4 TDCi Titanium
  • Year: 2009
Posted 27 February 2013 - 09:13 PM
This is the part I have been holding off buying/fitting for ages!
Thanks for posting the image Nath and thanks to Espen for starting this thread and welcome to the Forum! :D B)
#6 neps
neps
  • 79 posts
  • Name: Espen
  • Year: 2009
Posted 27 February 2013 - 09:42 PM
Ok so the mic is included in the loom (1710952). Thats great.
The multiline display you refer to, is that something I also would need? As far as i know the econetic has that display. Theres some kind of "game" there that rewards you when you drive eco-friendly. But if not, do you by any chanse have the partnumber for that display?
Also, still wondering about that headunit replacement. I know radio codes are a forbidden subject here, so i wont go there. But as for replacing the unit, it is possible to let the Ford dealer do the code stuff?
I attached a image of my dash here:
#7 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 27 February 2013 - 09:49 PM
The mic is not included, it just plugs in to that loom.
You would need the larger multifunction display, unfortunately I don't have the part number to hand.
They don't use radio codes anymore, it's all plug, activate and play! ;)
#8 neps
neps
  • 79 posts
  • Name: Espen
  • Year: 2009
Posted 27 February 2013 - 09:58 PM
Ok, so ill need to find a mic aswell. I guess this is a generic item? I can use one from my old handsfree set.
No radiocodes, thats great!
So, my steps is like this:
1. source all needed parts.
2. schedule apointment with ford for coding.
3. install parts a few days before schedule.
4. let ford do the coding.
What will happen when trying to use the car before its re-coded? Will it still be driveable? Will the normal radio functions be available?
#9 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 560 posts
  • Name: Allan
  • Year: 2009
Posted 27 February 2013 - 10:39 PM
What will happen when trying to use the car before its re-coded? Will it still be drivable? Will the normal radio functions be available?
I have the multi-line display and head-unit plugged in for my retro fit, and they both work perfectly, even the aux-in works!
USB and bluetooth don't yet as the module is neither fitted, wired up or programmed, but the stereo does all other functions fine so you "shouldn't" have to worry about the car not being drivable.
#10 neps
neps
  • 79 posts
  • Name: Espen
  • Year: 2009
Posted 28 February 2013 - 05:53 AM
I found the climate control kit! http://www.comesclim...=269&id=376#top
I have read through the instructions, basicly:
1. remove old control unit.
2. Install relaybox, closing valve, and the 3 temp sensors.
3. wire this up and install the new control unit.
Seems doable, but a bit pricey.
#11 gingertom
gingertom
  • 57 posts
  • Ford Model: Fiesta Zetec S
Posted 28 February 2013 - 04:35 PM
Hi you can get the mic from Ford it fits into an extended roof panel I believe finis 1681894 along with a steel bracket which clamps the panel finis 1535265. The display I had was finis 1698077 this was the red display I have seen them on ebay.The control panel replaces the old one although you need the trim panel as yours wont have the holes for the extra buttons. I don't think you need to swap the actual cd unit as I think they are the same across all models. I hope the finis codes are the right ones, they may have been superceded now, I did mine 2 years ago.
#12 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 560 posts
  • Name: Allan
  • Year: 2009
Posted 28 February 2013 - 08:23 PM
8M5T-19C112-AN
8M5T-19C112-AP
8M5T-19C112-AR
8M5T-19C112-AS
8M5T-19C112-AT
I got a B/T Module part no 8M5T-19C112-AM, not mini-USB, any ideas what loom I would need?
#13 neps
neps
  • 79 posts
  • Name: Espen
  • Year: 2009
Posted 28 February 2013 - 09:13 PM
Thanks, but when looking on ebay, and my local scrapyards websites, they list the cd/headunit together with the panel as one  part. Or did I misunderstand you here: "The control panel replaces the old one" By control panel, you mean the stereo buttons?
8M5T-19C112-AN
8M5T-19C112-AP
---snip---
Thats the exact same as iNath posted earlier.?
I took a look at the interior light/mic assembly on our 2010 Mondeo. This does also have the sunglass flip-out drawer. Seems like it would fit the Fiesta. Would the Mic be interchangeable also?
#14 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 560 posts
  • Name: Allan
  • Year: 2009
Posted 28 February 2013 - 09:44 PM
 Yeah, for some reason the "quote box" didn;t show round Nath's quote on my post?! :blink:
#15 gingertom
gingertom
  • 57 posts
Posted 01 March 2013 - 09:48 AM
There is a thread where someone has put the mondeo one in with the sunglasses holder. I didnt i used the fiesta part
I dont know about the mic being the same. I know the focus one fits because i bought mine originally for my focus before i p/x it for the fiesta and i removed the bits
