Hi All
Looking at changing the plugs in my Focus
I see there is a couple of different trains of thought with reguards to which plugs are best
I have been using Bosch super 4 purely to make life easy for the coil pack, as it failed in 2009 and was replaced with an intermotor coil (cheap and nasty in my eyes) however it has worked fine.
I am planning on fitting a new coil and leads (Bosch) as part of the next service
However,
I like the idea of NGK iridium spark plugs but would very much like your thoughts on this
also would these need to be gapped at 1.0mm as usual
Which Spark Plugs Are Best For An 04 1.6 Focus Fydb
Started by bt_cav, Feb 28 2013 10:25 AM
spark plugs
3 replies to this topic
#1
Posted 28 February 2013 - 10:25 AM
#2
Posted 28 February 2013 - 12:28 PM
the 2004 mk1.5 focus uses ngk plugs even the ford ones are ngk and yes the gap is 1.0mm
#3
Posted 28 February 2013 - 02:06 PM
Cheers for confirming that Artscot :-)
Whats your thoughts on the Iridium plugs over standard plugs?
#4
Posted 28 February 2013 - 02:41 PM
the laser iridium in my opinion were better than standard i never had starting issues the plugs seem to last longer up till then i changed them every year after the iridium they still didnt need changed after 2
the ngk iridium plugs should be LTR5IX-11
standard are tr5a-10
- Laser welded Iridium center electrode tip
- Platinum disc welded to backside of ground electrode provides long life
- Trivalent Metal Plating for superior anti-corrosion and anti-seizing
- Faster starts and quicker acceleration
- Better fuel economy and lower emissions
- Best OEM Iridium spark plug available
- Original Equipment Manufacturer approved design
Also tagged with one or more of these keywords: spark plugs
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Mk3 Fiesta Problems.Started by Mrmark941, 27 Jan 2013 |
Ford Focus Club →
Ford Focus Mk2 2005 1.6 Petrol Oil In Spark Plugs AreaStarted by boboguard, 23 Oct 2012 |
Latest Comments
More
