joiscey
Eac Fail
4 posts in this topic
hi has any1 ever had eac fail flashing on your dash on a mk6 fiesta zetec. if so how can i fix it on the cheap as dont have a lot of cash?
mk6 fiesta with eac fail flashing on dash HELP
I believe this is quite a common fault on the fiestas. Ford have brought out a repair kit for this problem i think, im sure i read somewhere that you get the electrical part of the throttle body, and the wiring loom that goes onto it, and other parts including the injectors. These two parts need to be replaced, and than the KAM needs resetting. This will need to be done by ford. Any ford garage will know what you are talking about. However, although ford say this should fix the fault, sometimes the throttle body does need replacing apparently. Hope this helps.
Cheers mate, any idea how much the repaier kit is and where to get it from? also what is the KAM?
