Focus Bulb Lists
Focus Bulbs
117 replies to this topic
#46 colinben
colinben
  • Budding Enthusiast
  • 107 posts
  • Name: Colin
  • Ford Model: Focus 3.5 Titanium 1.5 ecoboost
  • Year: 2014
Posted 09 October 2013 - 06:12 PM
RIGHT GOT iT NOW AFTER CHECKING  BI-XENON  HEADLIGHT BULBS
DIPPED BEAM      D3S
MAIN BEAM           H7
CORNER BEAM     H1
INDICATOR          W21 SINGLE CONTACT ORANGE
Thanks for all your help
Colin
Have something to contribute?
#47 DanGersFord
DanGersFord
    Dan The Gas Man
  • 3,498 posts
  • Name: Daniel
  • Ford Model: Fiesta ST3
  • Year: 2014
Posted 09 October 2013 - 06:16 PM
Hmm it must be different on the titanium and the st the because it's definately d8s bulbs on the ST bixenon headlights
#48 luke.grimbley
luke.grimbley
  • 170 posts
  • Name: Luke
  • Ford Model: Focus Titanium 2.0
  • Year: 2009
Posted 27 October 2013 - 03:41 PM
Updated FORD FOCUS MK2 FACELIFT (MK2.5) 2008 onwards.
Note: Bulbs have offset pins.
 Dipped Beam - 499 (H7)
Main Beam - 448 (H1)
Front Fog - 708 (H8)  H11
Sidelight - 501 Capless
Front Indicator - 382 Single Contact  BAU15S or 581 Amber/Yellow
Rear Indicator - 581 Indicator Bulb  BAU15S or 581 Amber/Yellow
Rear Brake Light - 780 Red  BAY15D or 380 Red
Rear Back Light - 780 Red  BAY15D or 380 Red
Rear Fog Light - 382 Single Contact  BAU15S or 581 Red
Reverse Light - 382 Single Contact  BAU15S or 581 White/Clear
Number Plate Light - 501 Capless  256 Festoon (longer festoon bulb)
Interior Light - 501 Capless Map lights / Festoon centre bulb.
Just to add after making the mistake myself..
The interior festoon bulb is a 239. Ordered the wrong size for my led conversion. Also made the mistake of thinking the rear dome light would be a festoon, it's the same as the 501's throughout the rest of the car.
As for the number plate bulbs, mine are 501's rather than festoon bulbs. Seems this can vary so i would check you specific car before buying. Could it be that the chrome boot strip uses 501's and the painted one is festoons?
Luke
#49 huey45
huey45
  • 95 posts
  • Name: Keith
  • Ford Model: Focus Titanium 1.6 TDCI Econetic 115Bhp
  • Year: 2012
Posted 12 December 2013 - 04:49 PM
Hi Guys
Anybody want to do a stickie as to what LED bulbs can be put into 2012> Ford Focus
and where they can be put, and with what types that wont give canbus errors ??
to get rid of normal filament bulbs !!
#50 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,242 posts
  • Name: James
  • Year: 2007
Posted 12 December 2013 - 04:56 PM
to be honest, you just search the bulb you want and search LED :) unless your car comes as standard with CANBUS then you wont be affected. You cant use LED Indicators, as they will flash like they have blown, so you would need to manually add resistors into the circuit.
Otherwise, if you need a 501W, then search for 501W LED, or if its a 42mm Festoon bulb, stick the LED on the end. Thats how I found all my LED's and can confirm that all are MOT passers :D
#51 huey45
huey45
  • 95 posts
  • Name: Keith
  • Year: 2012
Posted 12 December 2013 - 05:06 PM
Hi James
Thanks for that info, will do a trawl on flebay, unless you have a favourite site ?
Regards Keith
#52 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,242 posts
  • Name: James
  • Year: 2007
Posted 12 December 2013 - 05:14 PM
nah, trawling is the best way :P
#53 huey45
huey45
  • 95 posts
  • Name: Keith
  • Year: 2012
Posted 12 December 2013 - 09:22 PM
danke
#54 SuperSixFour
SuperSixFour
  • 34 posts
  • Name: Alex
  • Ford Model: Mk2.5 Focus Titanium
  • Year: 2011
Posted 19 December 2013 - 11:36 AM
Couple of questions about brake lights.
I have the ford LED rear lights but they use conventional bulbs for the brake lights. Can these just be swapped for P21 red LEDs or is it more complicated as with indicators?
I've also seen some people replacing the third/high level brake light with an LED unit from an XC70 but I can't find much about it, is it a straight swap or is there mor involved?
Oh and do we need can bus error canceling bulbs for our cars or are we ok?
Thanks for the help!
#55 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,242 posts
  • Name: James
  • Year: 2007
Posted 19 December 2013 - 11:48 AM
led brakes should be fine you may need dual filament but I have them on my cmax for led brakes and led tail and fog lights :-)
not heard of the volvo switch though...
sent using the Ford OC app for android.
#56 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 16,030 posts
  • Name: Clive
  • Year: 2007
Posted 19 December 2013 - 12:11 PM
Not heard of compatability with Volvo lights either.
I have one like this listing and it's a good looking bit of kit-
http://pages.ebay.co...id=360668013384
#57 SuperSixFour
SuperSixFour
  • 34 posts
  • Name: Alex
  • Year: 2011
Posted 20 December 2013 - 06:20 PM
led brakes should be fine you may need dual filament but I have them on my cmax for led brakes and led tail and fog lights :-) not heard of the volvo switch though
Thanks, I think I just need single filament because my side lights are Ford OEM LEDs and the fog is down in the bumper. I should really pop one out and check before I order though.
They all seem to have quite large heads which might complicate things because the bulbs push in from behind if I remember rightly. I'm not sure some of them will physically get through the hole.
Do you have any pictures of it fitted? Thanks
#58 Stoney871
Stoney871
  • Super Mod
  • 16,030 posts
  • Name: Clive
  • Year: 2007
Posted 20 December 2013 - 06:42 PM
#59 jordan_macgregor
jordan_macgregor
  • 88 posts
  • Name: Jordan
  • Ford Model: Focus Mk2.5 [08-10]
Posted 21 December 2013 - 09:43 PM
Should these just be a straight swap for the factory units alread installed?
http://www.ebay.co.u...=item35c741e4fb
#60 Stoney871
Stoney871
  • Super Mod
  • 16,030 posts
  • Name: Clive
  • Year: 2007
Posted 22 December 2013 - 11:00 PM
Straight swap, and will look very tidy.
Not what you're looking for?
Also tagged with one or more of these keywords: Focus, Bulbs
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
