Support the club!
Car Keep Cutting Out When I Push Brake
3 replies to this topic
#1 taylor89
taylor89
    Newbie
  • Pip
  • 6 posts
  • Name: Scott
  • Ford Model: fiesta mk 4
  • Year: 1998
Posted 03 March 2013 - 03:33 PM
Hi please help
I have a R reg ford fiesta with a 1.25 zetec s engine and I have recently changed it to a 1.4 zetec s and now and again the brake will go hard and wont stop me but when I push it the car cuts out and got to start it back up again, this have happened twice before and after messing around with bits and jumping on the brake pedal it start working again but it happened again last night on me I can't get it to work again I've tried everything that I use to do to make it work. I've asked around and people have said clean the idle air control which I have done. someone said it might have something to do with my ECU which I didn't change when I fitted new engine.
thanks Scott
#2 taylor89
taylor89
    Newbie
  • Pip
  • 6 posts
  • Name: Scott
  • Year: 1998
Posted 03 March 2013 - 04:17 PM
car cuts out on low revs
#3 jeebowhite
jeebowhite
  • 4,731 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 03 March 2013 - 05:26 PM
Could well be an ecu issue but also the you saying as soon as the brakes seize up the car cuts out?
#4 wase16ll
wase16ll
  • 325 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 03 March 2013 - 06:49 PM
could be a servo issue, if servo is failing/leaking air, brake pedal will go hard, takes real pressure to apply brakes....plus the air leak will cause the engine to stall...
with engine running check for air leaks/hissing around servo unit/ hose coming from servo and inlet manifold
